#1 Fuel pump dead
Old Jan 19, 2010 | 02:50 PM
subford's Avatar
subford
Originally Posted by Haz Tanker
Really?, The transfer between the tanks is because the rear pump flow is weak and cannot close the transfer valve, ultimately a weak pump or plugged pickup screen WILL cause this from reduced flow volume thus causing the valve not to close and making fuel go in to the front tank.
There are no transfer valve or selector valves to close. No selector valves at all.
Old Jan 20, 2010 | 05:43 PM
Jason Lewis's Avatar
Jason Lewis
Pump Update, So i have been running on the rear tank sence the front pump was replaced, the rear tank almost full when i filled it up on monday now in the parking lot the tank is at a 1/4 full, i switched to the front to see if any fuel was transfering over and NO FUEL WAS TRANSFERRD OVER IN THE FRONT !
Krisverde
18
Jul 17, 2015 07:47 AM
biggyfan1
48
Oct 31, 2013 07:26 PM
w6pea
May 21, 2013 03:34 PM
1mouse3
1978 - 1996 Big Bronco
20
Sep 10, 2008 04:37 PM
