Vacuum Line Routing
Old Dec 29, 1999 | 08:46 PM
Seven Four
Guest
Posts: n/a
Vacuum Line Routing
I have a '74 F-100 with a 300 I-6 and 1-bbl carb. Does anyone know of a source for finding out where all the vacuum lines are supposed to fit? I have a Chilton's Manual and have looked in Haynes, but neither have been helpful in this area.
Also, do you know off the top of your head which beds will bolt onto this same truck (8' bed)? Or where I can find a plastic bedliner for it?
Thanks for your help.
Old Dec 29, 1999 | 11:00 PM
BigBrownTruck's Avatar
BigBrownTruck
Vacuum Line Routing
Old Dec 30, 1999 | 04:56 AM
StockMan's Avatar
StockMan
Vacuum Line Routing
I can't help on the vac. lines, however, as to the truck bed question....it depends on whether you want functionality or originality. Any 8' bed between 67 and probably well into the 90's can be made to bolt up, but 73-79 would be the best range so that new bed would have the same body lines as your cab and bolts would line up well too. Either style bed would work too (Styleside or Flareside). I've seen many 80's style beds on the older trucks. The ones that look the best are the ones that are freshly painted to match the cab. I hope this helps.
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
rangerbud
May 20, 2015 09:06 AM
ty.Harris
Apr 21, 2015 08:35 PM
Loy
Oct 13, 2013 06:49 PM
dreo2003
16
Oct 9, 2007 08:09 AM
jsantos
1978 - 1996 Big Bronco
Mar 3, 2006 10:29 PM
