vin codes
Guest
Posts: n/a
vin codes
I have a 78 F-150 and i'm trying to determine what transmission and rear axle i have from the VIN codes. I purchased a Haynes manual but they dont tell you what the codes stand for. Is there a website where you can type in your VIN code and it tells you what the codes stand for?? I'm a novice mechanic but would like to learn and do more wrenching myself is there a better maintanence manual than the Haynes??
vin codes
I have VIN information on my site for 67 trucks only . That info will have some general application to other years, but not 78. There is a site which has a VIN decoder. I believe it encompasses your model year. You can reach it from a link off the FTE Main site. Good luck and let me know if you are successful.
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
vin codes
You can't tell from the VIN. There should be a Vehicle Certification label attached on the left front door lock face panel or door pillar. The following is from my 1978 Ford Car Shop Manual (but should apply to trucks also).
Trans: (Manual)
1: 3speed manual
5: 4 speed overdrive
6: 4 speed Borg Warner
7: 4 speed Hummer
Trans: (Automatic)
V: XP (C-3)
W: XP (C-4)
X: FMX
U: XPL (C-6)
Z: XPL (Special)
Axle Ratio
Y: 3.08
B: 2.47
1: 2.50
8: 2.73
2: 2.75
3: 2.79
6: 3.00
4: 3.18
7: 3.40
This may not explain everything (I typed it word for word from the manual) but I hope it helps.
Trans: (Manual)
1: 3speed manual
7: 4 speed Hummer
Trans: (Automatic)
V: XP (C-3)
W: XP (C-4)
X: FMX
U: XPL (C-6)
Z: XPL (Special)
Axle Ratio
Y: 3.08
B: 2.47
1: 2.50
8: 2.73
2: 2.75
3: 2.79
6: 3.00
4: 3.18
7: 3.40
vin codes
Here is that site address:
<a href="http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi">http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi</a>
The post which states you are not able to get the "axle and trans" info from the vin code is correct, but this site has a spot to plug in the other data from the warranty rating plate. This site covers 1970-80 trucks.
mfp4073
1983 - 2012 Ranger & B-Series
05-07-2015 10:25 PM
Famousamos
12-17-2011 06:49 PM
