Dipstick behind alternator?
Old Jan 12, 2010 | 09:10 PM
Danny Stroup's Avatar
Danny Stroup
I can't believe I just found this. What's it go to?
My oil dipstick is on the driver's side, the A/T is pass. side behind the block. This little puppy is RIGHT behind the alt in front of the cylinder head.
What the heck is it?
Old Jan 12, 2010 | 09:22 PM
cfrazier77's Avatar
cfrazier77
Its for car applications. It is normally sealed with a small plug. I have a dipstick in mine, a universal, to plug it. It does not pick up oil though.
Old Jan 12, 2010 | 09:30 PM
Danny Stroup
mine measures low and has black oil on it while my drivers side has clean recently changed oil showing correct level.
Old Jan 12, 2010 | 11:15 PM
dogmantra's Avatar
dogmantra
aaah.
I was wondering about that as well. Mine is plugged. I figured it wasn't done by accident but it was more than a little bit of a question.
Old Jan 13, 2010 | 12:37 AM
bmarkline's Avatar
bmarkline
Yeah it was originally a car engine then. Don't worry about that front one since you have the truck oilpan on it use that dipstick.
Old Jan 13, 2010 | 07:49 AM
Danny Stroup
So are you guys saying the factory installed 2 dipsticks?
Old Jan 13, 2010 | 08:36 AM
Blackfoot Big Block's Avatar
Blackfoot Big Block
If the engine was originally installed in a 4x4 truck, it would have a rear sump oil pan and an oil pan mounted dipstick.
If it was installed in a different application it would have a front sump oil pan and a dipstick that entered a hole in the timing cover. In a 4x4 application that hole would have been plugged.
A timing cover dipstick won't provide accurate oil level information for a rear pump oil pan.
