Sponsored by: Kumho
pitman shaft seal
Old Jan 12, 2010 | 08:40 PM
2020's Avatar
2020
pitman shaft seal
The 94 f-250 4wd is leaking a little around the pitman shaft at the bottom of the steering box.I got a seal kit for it.Is there any thing I need to know before tearing into it?I guess I just pull the pitman arm and pop out the seal?
Old Jan 13, 2010 | 04:27 AM
Lazy K's Avatar
Lazy K
Exactly. Once the pitman arm is off you will see a snap ring, remove it. It is then a matter of getting the old seal out. If it doesn`t come out easily you can start the truck and work the steering wheel and allow fluid pressure to blow it out.
Also take note of the order the washers and seal come out so that you can put the new ones in the same way.
Old Jan 13, 2010 | 04:40 AM
2020's Avatar
2020
OK,that's how I did some of the old 60's Fords in the past.
Dezl Newbie
Dec 6, 2016 12:39 PM
fordguy98
May 30, 2016 09:25 PM
460 FORD MAN
13
Aug 18, 2014 07:39 AM
dr1
Mar 22, 2008 03:03 PM
