1978 - 1996 Big Bronco
Need starter help!!!
Old Jan 12, 2010 | 08:28 PM
USAF FordGuy's Avatar
USAF FordGuy
Angry Need starter help!!!
So everything is back together, except starter wont fit!!! its an 89 351 bronco, the tranny is from an 84 5.0 bronco, both c-6. the starter from my 89 wont bolt up and the starter from the 84 ended up stripping out its teeth. Help! Do i really have to take it all apart again?
The last tranny i put in it was a c-6 from a 84 5.0 and it worked just fine so im quite confused
Old Jan 13, 2010 | 07:43 PM
b4hntn's Avatar
b4hntn
I'll say Hmmm...I don't know ... to put this at the top so the smart ones will see it again.
Old Jan 13, 2010 | 08:14 PM
USAF FordGuy
we found one that fits, but now the motor wont turn, not even manually. could it have seized from sitting for a few days??? GAAAAH!!!
Old Jan 13, 2010 | 08:56 PM
Encho's Avatar
Encho
The Southernmost Mod
Is the starter turning? an engine shouldn't seize for being idle for a few days, unless the engine was already going bad.
Old Jan 13, 2010 | 09:49 PM
USAF FordGuy
the starter works, we bench tested it first. It does have about 140k on it
Old Jan 13, 2010 | 10:32 PM
cOpE!'s Avatar
cOpE!
I had the same problem on a truck once. I thought the motor was siezed. I took the starter off, had it tested, it was good, took it back home hooked it back up and nothing. I had lights, horn, radio and everything...come to find out it was the battery ground cable, was juuuuust loose enough to keep it from turning over. Hope yours is as simple as that, good luck
Old Jan 14, 2010 | 10:57 AM
vtjvt's Avatar
vtjvt
will the engine turn without the starter installed?? if not then my guess would be something is binding in the trans/flexplate area, even with 140k the engine wouldn't seize from just sitting for a few days
Old Jan 14, 2010 | 01:25 PM
bertha66's Avatar
bertha66
Yes, it does sound like the T/C is not seated all the way in the trans and is binding the engine.
Old Jan 20, 2010 | 04:52 PM
USAF FordGuy
It only turns if the trans isnt bolted in. Someone said that if it isnt properly seated into the front pump seal, it wont turn. True??
Old Jan 20, 2010 | 04:55 PM
USAF FordGuy
oh the torque converter is from the 84 5.0, will that cause a problem even tho it bolted up fine and the splines match?
Old Jan 20, 2010 | 05:53 PM
USAF FordGuy
Problem solved, we put the torque converter in the trans first. Who knew?! Im used to the T-19A, i love that trans
