Nice report Chris. Especially with the miles you've racked up! I only have half the miles you show on the report. Isn't the Delo 400 in the left column though? I only noticed because I have had similarly strong Blackstone OA's on Delo 400 and noticed the strong additive presence. Particularly molybdenum and the boron. Always far above the universal averages.
You're correct. Delo is on the left, Valvoline on the right. Sorry
does anyone know how long i should go between oil changes with mobil 1? i really dont understand the whole sheering thing..i guess i have some reading to do. thank you very much
To explain the sheering thing, think of oil as a bunch of marbles. They add polymers to improve viscosity [think of pieces of string to keep the marbles from rolling away so easy]. When the oil is used in high stress areas of your engine those pieces of string get sheered into smaller pieces thus thinning the oil.
My last oil was Schaeffers 7000, and my truck did not like it, ran louder, harder cold weather starts, etc. Just switched back to 9000 and it is a whole new vehicle
Shearing in a 7.3L all depends on the mods you have done to you engine. So my question would be:
What mods have you done?
If your are not running a dual HPOP or High ICP programs then shearing is probably not a concern in your situation.
i just took all of my veggie stuff off of my truck so i am back to stock but i did install the super tuner perf-tow mod but i havent put the intake or the exhaust on yet. i hope that helped thank you again
makes sense...how long is a good rule of thumb between oil changes, with Mobil 1 syn..thank you
I would say 4-5,000 mile oil change intervals. I wouldn't recommend going over 5K without doing a used oil analysis report (some labs - Polaris $15, Schaeffer's $11, OAI $22, Blackstone $22).
Mobil Delvac 5W-40 has a good score on the Cold Cranking Viscosity test of 3200 at -25 deg Celcius. So if you live in a cold climate you will see good cold start characteristics.
So far it's been the opposite for me. I've found that when I do run 15w-40 oil, it shears faster than 5w-40. I've run Motorcraft, Delo, and Rotella dino 15w-40, and they can't make it much further than 3000 miles with dual HPOP's on my truck. That's why I typically run synthetics. They've all tended to resist sheering more.
5000 miles on a 15w-40 oil turns to the consistency of water. Synthetics will go about 8000 miles before reaching that point. However, I don't like running that many miles on those oils. I like to change them before they get to that point.
Sorry Curtis, I should have been more clear in my post. I was refering to 15W-40 synthetic Blends and not a 15W-40 dino. I have a few UOA reports on 7.3L running stealth & BTS pumps, and also on some 6.0L's. I'de be happy to share them for comparison. I don't like comparing apples to oranges (i.e. dual HPOP 7.3L's and 6.0L's) but as you know they both shear viscosity.
Happen to have a Used Oil Analysis report for comparison? Would like to see how the Schaeffer's 9000 is performing with your setup then the difference when you add your big oil mod.
To know for sure you need to have a couple oil analysis done. But if you're still talking about that 5W-30 you have in there, you really should dump it and get some of the other oils talked about in here. I go somewhere between 6000-7000 miles when I'm using synthetic.
