canister
Old Jan 3, 2000 | 05:52 PM
charles_1's Avatar
charles_1
canister
I have a 73 f100 with a 360. Theres some sort of a canister on the driver side wheel well under the hood. It has 2 lines connected to it and one line goes to the manifold. The canister appears to be empty since when you turn the engine off it pops like the suction had just stopped making the canister snap or make a popping noise. Anyway, my questions are, What does it do? And should it have something in it or is the popping noise normal? And finally, is it something that I really need to have hooked up?
Old Jan 3, 2000 | 06:24 PM
oleblue70's Avatar
oleblue70
canister
hey charles,the canister is your stored vacuam for your temp. controls in the cab.it opens and closes the gates in the duct work.it runs all your cimate controls on the dash.your year was the first for this.72'and under were all mechanicly operated.as for the popping it's all ok if you have no vac. leaks and your dash controls all work.oleblue=
Old Jan 4, 2000 | 02:57 PM
charles_1's Avatar
charles_1
canister
Thanks for the response, I've never heard of that. I always thought it was some sort of fume thing from the gas tank.
Old Jan 4, 2000 | 06:06 PM
oleblue70's Avatar
oleblue70
canister
hey charles no problem.oleblue=
Old Jan 4, 2000 | 08:36 PM
390fe's Avatar
390fe
canister
alchemist1
17
Mar 18, 2020 07:24 AM
Dusty Wooddell
1983 - 2012 Ranger & B-Series
Oct 15, 2011 07:37 PM
92Bronco351
1978 - 1996 Big Bronco
Oct 24, 2006 11:45 PM
sgreen
Engine Swaps
Mar 14, 2006 07:09 AM
