I tried to use the identical add between my hometown and Detroit and it got deleted. Changing it a little helps sometimes, but at other times that also gets deleted as "similarly worded add noted".
crazedlist.org : search craigslist like a madman lets you selectively choose what areas (cities) you search. That way if you are searching for something semi common you don't search the 300 or whatever areas they have listings in...
Yeah i am on there all the time also, in fact getting ready to post my 77 highboy, and if you list it in different areas you will need to change it up quite a bit as far as the listing goes. I have done that also and if it is to similar to your other post it will reject it. Or someone will mark it thinking it is spam.
