Alignment?
Old Jan 11, 2010 | 04:52 PM
biggietx's Avatar
biggietx
Alignment?
I am having problems with my Ex. I have had it aligned 4 times and they are telling me it is straight as an arrow. I have a strong pull to the right and i just had to replace the front tires because they were worn BADLY along the inside of the tires. I feel like it might be a suspension problem but I am not sure where to start. Has anyone else run into this?
Old Jan 11, 2010 | 05:07 PM
katiesdad7's Avatar
katiesdad7
2 or 4 wheel drive?
Old Jan 11, 2010 | 05:09 PM
biggietx's Avatar
biggietx
it is a 2wd
Monsta's Avatar
Monsta
Sit. Stay.
At the same shop??
Old Jan 11, 2010 | 05:11 PM
biggietx's Avatar
biggietx
Originally Posted by Monsta
At the same shop??
I have the lifetime alignment from Firestone so its free.....the 4th time I went to another shop to get a second opinion.
Old Jan 11, 2010 | 05:12 PM
cbradford's Avatar
cbradford
Was it a real alignment or just a Tow and go?
Old Jan 11, 2010 | 05:13 PM
biggietx's Avatar
biggietx
Full 4 wheel rack lift alignment.
Old Jan 11, 2010 | 05:19 PM
cbradford's Avatar
cbradford
That don't mean they did a complete alignment, some places will just adjust TOW and send you on your way saying they did a alignment. This is why I will always ask for a print out of before and after because there is more than Tow to adjust such as CASTOR and CAMBER.
Old Jan 11, 2010 | 05:40 PM
biggietx's Avatar
biggietx
I took it in expecting it to possibly need a camber kit but the told me the camber and caster was fine.
Old Jan 11, 2010 | 05:44 PM
cbradford's Avatar
cbradford
Next time ask for a "reduced tolerance" alignment, which will tighten up specs and if they will not do this find another shop.
johnjohn2784
Apr 6, 2010 12:12 PM
scstocks94f150
Jul 3, 2008 05:50 AM
bjjf350d
1983 - 2012 Ranger & B-Series
Nov 22, 2006 09:07 PM
F150_Luvaa
Apr 6, 2002 08:59 AM
pzcalgal
May 18, 2001 04:46 PM
