Head Light Issues....HELP?
Old Jan 11, 2010 | 07:37 AM
JB_85F150's Avatar
JB_85F150
Okay, I've got a 1985 F-150 that I've been working on restoring. Well, I got the truck back to the body shop. The truck did have two running lights on the roof, well I had the body shop remove them and weld up the roof. Now I got the truck back, The head lights will not come on.
In fact, when it turn on the headlight switch, the blue high beam indicator light comes on even if I turn the high beams off or on, and still nothing coming on with the headlights...........Its driving me crazy, I'm to the point now to where I can drive the truck again while its being worked on but need this fixed so I can drive at night.
I'm confused.
thanks,
Josh
Old Jan 11, 2010 | 09:08 AM
86bigred's Avatar
86bigred
Sounds like the high beam switch is defective.or since it was in the shop did somebody unplug the lights.
Old Jan 11, 2010 | 10:01 AM
JB_85F150's Avatar
JB_85F150
I checked to make sure the lights were plugged up and they are. I could understand the dimmer switch going bad, but I would think that it would not cause the headlights to not work...........
I'm thinking that possibly when the removed the rood running lights and just cut the wires, that it possibly broke the circuit somewhere, but I'm not sure. I guess I'll just keep tracing and looking, if anyone thinkgs they can help me with this problem, please post up.
thanks again guys,
Josh
Old Jan 11, 2010 | 10:16 AM
86bigred's Avatar
86bigred
The roof running lights should have a connector behind the drivers side kick pannel,brown wire if I remember corectly.the head lights should be on a seperate circuit from the head lights.I would unplug the high beam switch and find out if there is power at the plug,should be red yellow wire.if there is power,jumper it out to one of the other plugs,if the light come on the switch is defective.
Old Jan 11, 2010 | 10:18 AM
bashby's Avatar
bashby
There is a wire connector in the drivers rear cab corner that feeds the lightts on top of the truck, I'd unhook it so you donrt get a short were you cut the wires. It wont have anything to do w/ your headlight problem though. A bad headlight switch or dimmer switch could cause your problem (among other things) check the dimmer switch first, its easier to get to. The plugs tend to fail as much as the switch itself. With the headlight sw on you should have power to the dimmer
Old Jan 11, 2010 | 10:19 AM
Franklin2's Avatar
Franklin2
The dimmer switch certainly can kill the whole headlight circuit, since they run directly through it.
Old Jan 11, 2010 | 12:24 PM
JB_85F150's Avatar
JB_85F150
Thanks guys, I'll give it a look in the next day or two. Is there any pictures or anything to help my identify some of these connectors?
thanks again,
Josh
Old Jan 15, 2010 | 04:51 PM
JB_85F150's Avatar
JB_85F150
I just wanted to say thanks guys for helping me out. I went to o'reillys auto parts and got a new dimmer switch. put in in and what do you know. I have working headlights again.....
thanks again for your help.
Josh
