New Exhaust Thread for clarification
Old Jan 10, 2010 | 10:15 PM
wreckinball's Avatar
wreckinball
yeah i just want to see what it is like with out any major restrictions. that y is a T and it blows donkey *****. I just want to be able to possibly pull a burn out from a stop without being on a wet metal burn out plate LMAO!
Old Jan 10, 2010 | 10:37 PM
starmilt's Avatar
starmilt
I have a flatbed on my 84 but when i built it the reason for the flatbed was to haul hay on so stacks was not an option. they would look good though.
Old Jan 10, 2010 | 10:44 PM
mechelement's Avatar
mechelement
I took a look today because of this thread. It looks like it'll be a real PITA to route an exhaust pipe down the driver's side. My exhaust comes down from the exhaust manifolds couples into one and then splits again and there are two exhaust pipes running parallel with one another down the passenger side of the truck. One pipe broke off around 3/4 of the way and the other has a turn-down tip.
Old Jan 10, 2010 | 10:54 PM
wreckinball
i think i am just going to have dual 3 in pipes down the passenger side. from where the drivers side pipe takes the turn to the passenger side i am going to run at a nicer angle to the passenger side and then run parallel down the side. I am going to just run them out the side with chrome tips but here is the question, will the exit times of smoke be different? If so i need to find a dual 3 inch into single 4 inch connector. Problem is where the hell do i find that? hahaha
Old Jan 10, 2010 | 11:01 PM
starmilt's Avatar
starmilt
LMOA who the hell knows. that is splitting hairs ain't it.
Old Jan 10, 2010 | 11:03 PM
starmilt's Avatar
starmilt
I guess you could give the hippies a one two punch .
Old Jan 10, 2010 | 11:04 PM
wreckinball
i was just wondering because i like the way it blasts it out in one good jet. If it was in two different timed events i wouldnt think that was nearly as cool. How can i run two pipes like that into one?
Old Jan 10, 2010 | 11:16 PM
mechelement
If you run true duals, are you going to install a cross over pipe between the duals?
Old Jan 10, 2010 | 11:19 PM
starmilt's Avatar
starmilt
Tin snips,die grinder and a wire welder build a collector out of 4" for the two into one.
Old Jan 10, 2010 | 11:28 PM
wreckinball
condensing two 3inchers into a four would be a chore i am thinking. i would have to condense the two 3 in pipes down a lot to get them both into one 4in pipe.
Old Jan 10, 2010 | 11:30 PM
wreckinball
what is the crossover for?
Old Jan 10, 2010 | 11:43 PM
mechelement
The crossover equalizes pressure on both sides and doesn't allow a resonating effect to go back up into your manifolds into the heads. IIRC, you can mess up the motor w/o a cross over pipe. I'm not sure if it applies to diesels, but I'd imagine it would... Here's a good read on crossover pipes: http://mustangforums.com/forum/2005-...explained.html
I ran my Ramjet 350 w/o a crossover pipe in my Jeep. After the H-pipe was installed, I noticed a significant improvement in overall response, power and it really smoothed out the exhaust.
Old Jan 10, 2010 | 11:54 PM
  #28
wreckinball
the power increase over the old system is so profound that i cant imagine i am having any issues. But if i am going to run them side by side i can look into the channel system if i find i am having issues.
Old Jan 10, 2010 | 11:57 PM
  #29
mechelement
I installed an H-pipe on my gasser so I didn't screw up the motor. I didn't care about anything else.
Old Jan 11, 2010 | 12:05 AM
  #30
starmilt's Avatar
starmilt
The old torinos came with a crossover but I have run duals on everything I have owned for the last 35 years and never put a crossover and got200,000 miles out of nearly everything.
