I'm doing the powersteering conv and need to know
What Type of fluid it uses i was told ATF is
this true? All the stuff is out if a 75/F350
Also do i need the return pipe loop (must be a cooler of some kind)or can i hook the return line
right to the pump? Thanks to any reply's
This is going into a 72/F250/360/4speedstd
Now I'm confused. I'm doing the conversion on a '69 F100 with parts from a '77 F150. When robbing the donor truck, there was no sign of a cooler and both lines went directly to the pump. Was a cooler only used on the larger trucks? I noticed that the donor in this post was an F350.
sc I used a 76F100 for my 66F100. There was a metal tube line that came from the gear, and zig zaged back and forth along the chassis rail, like a refrigarator line and then up to the pump.
I can't make an arguement for it. I have only heard stories of burned up pumps, and the trucks did come with them.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
