Sponsored by: Auxito
Help! Tesnsioner!
Old Jan 9, 2010 | 11:16 PM
Cain64's Avatar
Cain64
Help! Tesnsioner!
So not sure if its the un normally cold weather we are having in GA or what but, today i started hearing this whinning noise along a kind of click. I think its coming from the belt tensioner but im not completelly sure..... any thoughts or sugestions would greately be apreciated.
Old Jan 10, 2010 | 07:03 AM
torkum's Avatar
torkum
To make sure its on the drive belt system you can take the belt off and start the engine [only run a minute or so]. If the sound is gone it could be the tensioner or idler.
My alternator bushings make a little noise when its this cold [below 25].
The click could be you A/C compressor kicking in and out when you have the defrost on.
Old Jan 10, 2010 | 07:57 AM
Cain64's Avatar
Cain64
i know its not the a/c cause i turned all that off to make sure. And ive narrowed it down to the alternator/alt pulley and or bearing or the idler im gonna check tension and all and maybe try a little bit of conditioner and see what happens
Old Jan 10, 2010 | 06:39 PM
EZFEED's Avatar
EZFEED
Dust gets in the bearings and causes squeaks and squeals. Did you pop the belt off?
Old Jan 10, 2010 | 07:23 PM
Cain64's Avatar
Cain64
I just put a new idler pulley on today and used some belt conditioner on it and the squak came back but idk what it is the pulleys are fine im guewwing its just the paint on the new pulley
Old Jan 10, 2010 | 07:47 PM
EZFEED's Avatar
EZFEED
Did you spray a little oil in the Alternator? Sometimes the brushes will make noise or the bearings.
You popped the belt and listened to it?
Old Jan 10, 2010 | 08:32 PM
Cain64's Avatar
Cain64
No i have not taken the belt off ill do it in the morning. And no its not from the alternatotor its a belt or pulley even though i jusdt replaced it
Old Jan 10, 2010 | 08:33 PM
EZFEED's Avatar
EZFEED
You tried using a stethescope? (sp) I piece of tubing works well for this and can help eliminate the problem.
Old Jan 10, 2010 | 09:01 PM
Cain64's Avatar
Cain64
Nope not yet.
