diagnostic ports
Old Jan 9, 2010 | 10:14 PM
Rusty924x4's Avatar
Rusty924x4
diagnostic ports
Today I received my Ford code reader in the mail. I have a 92 f150 300 6cyl. 4x4 with the check engine light on. I am looking for the self test input plug. I think that there are two different plugs to plug in the code reader to test the codes? One is the self test connector and the other is the self test input. Where is the self test input? I do have a chilton but I don't know where this plug is at. Is this plug in front of the six plug self test connector. And the self test input looks like one plug by itself. Where is this one plug at? Thanks
Old Jan 9, 2010 | 10:18 PM
Conanski's Avatar
Conanski
Go to Ford Fuel Injection and check out the article on doing a self test.
Old Jan 10, 2010 | 04:12 AM
Lazy K's Avatar
Lazy K
What he says.
Old Jan 10, 2010 | 05:09 PM
Rusty924x4's Avatar
Rusty924x4
ok, codes 522,10,332 so i think i need to change the egr sensor. Where is this on the 300 6 cyl?
Old Jan 10, 2010 | 07:38 PM
DBGrif91's Avatar
DBGrif91
Actually, code "10" is just the separator code. When you did the test, did you have the engine running or not? Because if not, "10" indicates that code 522 is a KOEO [Key On Engine Off] code and 332 is the CM [Continuous Memory] code.
Old Jan 10, 2010 | 07:54 PM
Rusty924x4's Avatar
Rusty924x4
the engine was off. The instructions said to turn on key but not start the engine. And the chilton said that code 332 is insufficient erg flow detected Heck, I can't even find the erg sensor. is this on the left side of the engine Thanks DB
Old Jan 10, 2010 | 07:56 PM
Rusty924x4's Avatar
Rusty924x4
And this is on a 92 big six
Old Jan 10, 2010 | 10:00 PM
Conanski's Avatar
Conanski
Either the EGR valve is stuck or the vacuum line between it and the EVR is broken, test for this and proper EVR function before testing the valve for ocrrect operation before removing it.
The EGR valve is just behind the TB on the upper intake neck and the EVR will be next to the coil.
citygator
Feb 3, 2017 06:25 PM
kfcoltn
Aug 29, 2016 11:34 AM
augoldminer
1983 - 2012 Ranger & B-Series
Mar 20, 2014 04:54 PM
JRSutton
18
Sep 11, 2012 11:07 AM
steve83
Computer Chips & Tuners
May 19, 2003 05:50 PM
