Sponsored by: Real Truck
battery FAILURES
Old Jan 9, 2010 | 10:13 PM
1085's Avatar
1085
battery FAILURES
2009 F350 V10 4/4
ABOUT 2 WEEKS AGO MY FORD DIED.TOWED TO THE GARAGE AND THEY CHANGED THE BATTERY.THEY SAID IT WAS A SHORTED CELL.TODAY THE BATTERY FAILED AGAIN.PULLED IT OUT TESTED IT WITH A 100 AMP LOAD AND IT GAVE ME 300 AMPS.THE BATTERY IS A 650.WHAT GIVES WITH THE FORD BATTERYS OR IS THERE PROBLEM OUT THERE?MORE AND MORE GUYS ARE TELLING ME THEY HAVE THE SAME PROBLEM BUT THEY HAVE PLOWS.
Old Jan 10, 2010 | 12:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
WHY ARE YOU SHOUTING?
No, battery failures are not real common at all. Sounds like something is not correct with your charging system.
Old Jan 10, 2010 | 06:24 AM
1085's Avatar
1085
BATTERY FAILURE
TRUCK WAS AT DEALER . THEY CHECKED FOR FAULTS AND DRAIN ON BATTERY.THERE WERE NONE.ALT WAS GIVING 128 AMPS I BELIVE.
Old Jan 10, 2010 | 06:30 AM
redford's Avatar
redford
Dude,
The caps lock is the key just to the right of the "A" key.
If the alternator is producing 128 amps and the batteries are new, check your cables. Obviously, something was overlooked.
