No.8 fuel delivery ?
Old Jan 9, 2010 | 09:48 PM
jblueguy's Avatar
jblueguy
Great forum. Thinking about a '99-03 7.3 to pull a bobcat. I read there are problems with fule delivery at No. 8 due to an engineering flaw. Any experience with this? Is there a fix that won't cost an arm and a leg? This engine would be much better than a 6.0, yes? Thanks
Old Jan 9, 2010 | 10:02 PM
ChunderDownUnder's Avatar
ChunderDownUnder
G''Day M8 and welcome to FTE. The CCK mod is the fix you are lookn for. I used this one
Dino Fuel Alternatives | Product Detail
The best fix for the fuel rail is the full regulated return
Ya best bet would be to give Clay from Riffraff diesel a yell. He can fix you up.
Riffraff Diesel: 1999-2003 7.3 L
Old Jan 10, 2010 | 02:05 PM
UNTAMND's Avatar
UNTAMND
I would reccomend clays kit. It is a true bolt in and has an awesome machined adaptor block. No cutting required. Just bolt it in.
Old Jan 10, 2010 | 04:00 PM
farmb0y's Avatar
farmb0y
Welcome to FTE!!
Great question and these guys already got you on the right track.
It's not necessarily a problem, until you do some custom tunes and/or bigger injectors. The #8 injector fires directly after #6. Fuel for that side of the engine is supplied from the front of the block, so when #6 fires, it can leave a "void" of fuel for the #8 injector when it fires. Ford's "band-aid" for the issue was a long-lead injector. But the best fix is as mentioned above with a CCK or even better the regulated return.
Let us know where you are located and when you find a truck that you're looking at. There may be one of us in your area to help you out and could possibly take a look at it for you.
Old Jan 10, 2010 | 09:49 PM
jblueguy's Avatar
jblueguy
Thanks a ton! I am considering Lenz Truck Center in Indiana. I am in Toledo. It's a drive, but no one around here has a 7.3 crew cab. This prob won't happen until spring.
