Hi. I have a 94 f250 hd with a 5.8 and a 5spd and over 300,000 miles
on the original engine. This truck has run beautifully until 2 days ago when it started to loose power and drag if I keep my foot in one place; if I accelerate or let up it seems to clear up most times. I'm thinking it's the TPS, but can't find anything to confirm this. It's not throwing any active codes at this time. It just passed inspection this week. Any help would be appreciated.
No codes meaning the check engine light hasn't flashed or that it gives the all clear 111 code for both KOER and constant memory? If it's the first scenario then you need to check for codes because they will not always trigger a CE light.
