Winter is here
Old Jan 9, 2010 | 09:15 PM
edsf100's Avatar
edsf100
Winter is here
Classic Pickups Garage
Well it's another winter day in California.
Old Jan 9, 2010 | 10:09 PM
52 Merc's Avatar
52 Merc
Do me a favor and send me a bottle of 80 degrees, please. ;-)
Old Jan 9, 2010 | 10:43 PM
Earl's Avatar
Earl
I hear all about how great it is in California right up until the upper deck of the highway falls on whomever I am talking to and smashes their cell phone - among other things.
Mark Twain is often misquoted as saying "The coldest winter I ever spent was a summer in San Francisco." The fact that it is a misquote does not detract from the (at least partial) truth of the statement.
So there you Californians. Now, if I could only figure out how to get my socks free of the floor to which they seem to be frozen, I could go put another log on the fire.
Old Jan 9, 2010 | 10:57 PM
Stephen67's Avatar
Stephen67
It was -17 here yesterday, with -40 wind chill. Thats cold enough that boiling water explodes if you toss it in it the air, or steel starts to loose it's strength and you can hip a door handle off... which I still have.
On the bright side, it keeps all the California's from living here year round, lol :P
Old Jan 9, 2010 | 11:10 PM
59flatbedford's Avatar
59flatbedford
i live in the same town in Stephen67 so kiss my insulated garage.
Old Jan 10, 2010 | 12:47 AM
SunDown's Avatar
SunDown
I like Stephens version of "on the bright side"!
Old Jan 10, 2010 | 01:43 AM
Julies Cool F1's Avatar
Julies Cool F1
Well, it could happen to us I guess---look at what's happening in Sunny Florida this week!
Old Jan 10, 2010 | 07:52 AM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
we where 0 last night before the wind chill factor!! Nasty out had to work on the wifes truck last night and lucky for me i have some heat in the garage but it does go to the highest part of the garage ceiling. Im thinking of a fan install is in my future!! Keep warm people!!!!
Old Jan 10, 2010 | 08:18 AM
rbig1's Avatar
rbig1
i,m having the same problem with my heat it all goes to the rafters first then an hour later it gets warm then every thing starts to sweat dont know if a ceiling fan would work for me though not enough clearance. the sweating of tools is what i dont like
Old Jan 10, 2010 | 10:37 AM
Earl's Avatar
Earl
rbig, that sweating is killing me. I have two large electric heaters in a largish two-car garage (only Earl and tools, parts, etc. are in the garage). I can't afford to keep it heated all the time as it's not really insulated. It seems like every time I go out (at least in the winter) to get a metal tool or part, I find it has rusted wherever water has condensed on it. Like you, the condensation happens when I turn the heaters on and add hot, moist air to the very cold metal items.
I swear I'm going to use our retirement funds to build a nice, big, HEATED workshop. Well, maybe not - the BOSS would make me sleep out there if I did. And she'd disconnect the heat.
Old Jan 10, 2010 | 11:23 AM
Julies Cool F1
Yeah Sweating!
It's supposed to be up to 80 degrees here today with 5% relative humidity. Might have to turn on the "Air."
Old Jan 10, 2010 | 11:38 AM
rbig1's Avatar
rbig1
yes my tools get serface rust on them. i take all the meters and special wrenches and battery impacs in the house tried electric heater on tool box but have to many boxes they still get wet. have to stay out and dry the expensive tools and spray down drill press and valve grinders cant be good for welder but dont know how to stop it. my shop is 85% insulated dont seam to make any diff. need to buy better doors cold air goes through them. thought about foam blocks but what would they look like on inside of door
Old Jan 10, 2010 | 11:49 AM
Julies Cool F1
If you have humidity problems, try buying a sheet of Drywall and four 5 gallon paint buckets.
Break the drywall up into 4x4 inch pieces and put it inthe buckets. Put a bucket at the center of each wall in the garage. Maybe put a couple 2'x2' chunks up against th ewalls as well.
It absorbs quite a bit of moisture.
Also, there are dehumidifiers available at Home Depot that aren't too expensive.
Old Jan 10, 2010 | 11:58 AM
Fomoko1's Avatar
Fomoko1
It never warms up enough around here to make anything sweat, count your small blessings.
Old Jan 10, 2010 | 12:06 PM
Earl's Avatar
Earl
Those ideas are good advice, Julie. In some climates like where I live in Ohio, we get large temperature and humidity swings. That makes it a little tougher to stay on top of things.
The real problem is my furry four-footed child who wants to go outside to do her business. Apparently she has to do this 2 or 3 times a day. I've tried to train her to stop the problem, but she insists on it. I have to leave the back man-door on the garage open all the time as she is getting older and needs to have unhindered access to her toile ... I mean our back yard. If I could close that door all the time, your suggestion about the humidifier would be my first action.
Temperature changes in uninsulated spaces are hard to control. Heat can (and does, as we all know) pass through ceilings, roofs, floors, walls, windows, and closed doors.
Large humidity changes can only happen if a large amount of air is being exchanged between (in my case) the garage and outside. Water vapor does not go through walls, windows, or doors unless you have some pretty crappy walls, windows, or doors.
