Considering a 6.0 and a few questions in general. << own a 7.3 now
#33
While you MIGHT be an educated man, Mr guthrie, my common sense devours you. You came here asking for help that you generously received from several upstanding members who know the 6.0 pretty well. I would certainly have welcomed any of their advice, you chose to do otherwise and thats fine. I am done trying to help you, and with this thread. I will try to focus on some others that I might be able to help. I sincerely wish you good luck with whatever decision you make.
#34
Received 1,466 Likes
on
Interesting response after receiving some sincere solid advice. My advice is sincere too and that is to stay away from any 6.0 and I mean any. No matter how few miles, and how great the price stay away. This isn't the engine for you.
#35
on
1 Post
Why, because I would run 15w40 in it? Do all the other posters have to put up with this stupidity if you find out they are running 15w40? How does running that oil reflect my mechanical abilities?
By the way, most of the advise was tried and true and I appreciated it. Where I took issue was with the oil issue. If you guys can show me with definitive proof that running 15w40 oil in a 6r is so bad to the point I should be chastised from ever buying one, I will concede and apologize. I just don't see how it really makes that much of a difference When the oil samples on my truck at 255k show perfect wear and the lab and I both decided that I would not see any benefit from switching. How and why is the 6.0 so much different?
#36
on
I didn't say dino oil was bad, I said synthetic oil is better and it's better in ways that you can't see in an oil analysis alone. There are quite a few of people that have had better oil analysis from synthetic oils then regular dino oils as well.
Synthetics are known to be able to stand more extreme operating temps, tell me, do you know what the average operating temp is for the major engine vitals? Particularly that of EO? Do you actually know if what operating conditions that you are going to be running your truck and what is sufficient for that 6.0 truck with what little you do know(according to your own admission)?
No, what reflects your mechanical abilities is that fact that you said that you didn't know alot about the engine. That is what reflects your know how with this engine specifically.
Running synthetic has been known to show the benefits that we have told you about. Something that you really can't notice alot of a trend in an oil analysis. It is tried and true and there are alot of people that have various test results to show it as well. People that know more about this engine then you do(based on your own admission of not knowing alot about this engine).
#37
on
1 Post
Forget it I am done. how is it the rest of the world can live with their 6r's without knowing this tidbit of wasted mental space? this thread got stupid. I am sure all of you guys are great guys but I fail to see the point of this thread anymore. All needed to know was how much the maintenance was going to cost me and the mileage.
#38
Look no one is telling you that you have to run snythic. Sure lots of people run Dino 15w40 and never have a problem. I did for 100k miles and then my injectors starting sticking. I switched to the 5w40 synthic and the truck ran 10 x better. It cured most of my sticktion problem. never looked back since. Using synthic is more of a preventive measure if you don't want to use it then don't. But the only thing you keep bringing up is oil samples that is not a factor in running it or not. We are just trying to suggest to you what would be good preventive maintance. There realy is not much price difference in the two oils IMHO. The price of 8 injectors and my truck being down out weighs it so for me I don't take any chances. It's that simple man really.
#39
Now for my .02. The best way to describe these two engines is like this. The 7.3 is like a street walker you can use her any way you want and she didnt care. The 6.0 is like a high maint. wife. She needs all the attention and is very picky about what you give her. Ex. Filters and oil. I learned all this pretty much by my ignorance by not listening to these guys on here. If any of these guys tell you something it is gold. A man who definatly knows his engine is tex. Just look at his sig. The only thing that i have not done that they suggested is go to synth. Oil. I still use rotella dino oil. I have just started having stiction problems and WILL be swapping to the synth. Rotella next oil change. So just bad talk all these guys all you want and when you come on here with a problem dont be suprised if noone responds. P.s. USE FORD FILTERS. Dont skimp there like i USED to do.
#40
on
You are coming from a background in the 7.3, you treat that engine differently then you do this one. There are alot of people here that know better about that you do. What's going to happen is that you are going to run into some problems and due to your flippently disregard for people that have years of knowledge on how to make a truck that has it's design flaws and still make it dependable even with having those design flaws, how many people do you think will help you as readily as they have now? Most people will tell you, I for one have a very long memory and I don't let go easily.
Worrying about just the purchase of the truck is incredibly shortsighted of you. Purchase is the easiest of it all. Keeping it in good working order is entirely different.
They are at the mercy of their dealership and the techs there. That is hit or miss when it comes to success rate with the 6.0. Oh by the way, you don't know exactly how the rest of the world lives with their 6.0, they may not be living all that well with it. Point is, you know how well we live with it and you know part of why that is, but instead, it goes against your thinking so you speculate on the rest of the world. Not very logical. Also, you have to remember that the bad feeling towards the 6.0 is more prominate then the good feeling towards it(another difference between it and the 7.3), if you were to go off of that(given that you admitted not to knowing much about the engine itself) and speculate how the rest of the world lives with their 6.0(assuming that they don't do what we are suggesting, which would be the only way speculating would help yu in this case) I wouldn't think to good given the prevailing sentiment towards it.
As to EOT and the other readings as well(ECT, and TFT etc), those also factor in moreso with the 6.0 then it does with the 7.3. Alot of design flaws that are in the 6.0 can be mitigated with one knowing what those readings should be and what readings your truck is actually giving. But hey, you didn't want to know that, you are only concerned with the one time issue of purchasing the truck, so why am I wasting my time, be giving you all this information that would make you a better informed buyer and if you really want to deal with the 6.0 and all the costs that go into it. I know exactly how I live with my 6.0, I don't care to speculate how the rest of the world lives with it.
#42
It don't get cold enough here in tx to use a block heater but iwould use it anything below like 15 or so. Don't need any additives in the oil, but alot of user use fuel additives in every tank (including me). What kind you use is really just personal preference but most use diesel kleen, power service, 2 stroke oil, or ford centain boost. There are a lot of them but that is what I see most user on here use. I use diesel kleen my self.
#43
on
Careful Tex about this statement... Matter of fact there's a member here (not going to say names since it's irrelevent) that has high iron content while using synthetic oil. As a matter of fact I've looked at many UOA from the 6.0 with conventional vs synthetic and can't tell a difference. I've seen samples were both produced faily decent results and some not so good.
Bottom line is the recomendation to use synthetic oil to this guy is nothing wrong and synthetics deffinitely help with stiction problems if and when they occurr.
#44
on
There is only one guy that I know of that is running synthetic with a relatively high iron content. I believe that his synthetic of choice was BD, is that the same person that you are thinking of?
#45
