where can I get these bolts
I need to find the bolts that are used in the front double-cardan drive shaft of a 89 F350. These are the blots that fix the double-cardan u-joint to the yolk at the t-case... I went to ford and they want 25 bucks a piece for them! that's a hundred bucks for 4 bolts!!! Any one have any ideas on where they might be available.
Thanxs for the replies guys... I don't have the old bolts so I have no idea what they are supposed to look like... But i can say that it looked like they would have to be a very specific bolt with a small head like maybe an allen head and shouldered. That's why I thought I'd ask here.
Ya we got NAPA up here in canuckastan... and paved roads too! LMAO!!!
I'm going to see if I can find some at the bolt store... thanxs
I'm going to a place locally that has a big assortment of specialty blots... all the other places I've gone to including napa didn't have the right ones...
These are the bolts that fix the double-cardan u-joint to the yolk at the t-case...
I went to ford and they want 25 bucks a piece for them! That's a hundred bucks for 4 bolts. That's friggen ridiculous!
385883S100 .. Bolt-12 point / 5/16" -24 / 1 1/4" from shoulder to end / Thread length: 1 1/8"
MSRP each: $16.00 / FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price each: $9.60.
PARTSGUYED aka Y2KFORDPARTS.COM = MILLENNIUM FORD in Seattle WA.
Rebocarbo: The 1980/89 & 1990/2002 Ford Truck Parts Catalogs lists these same double carden bolts from 1980 thru 1997.
25 bucks for a 2 dollar bolt...i really think some dealership parts guys are lining their pockets with money from suckers....because SOME people would think that is the only place to get that bolt.....go to the hardware store, spend 65 cents on ONE of the bolts that gearhead251 mentioned, then see if it fits...if not your out less than a buck, if it does, go buy more...and use some friggin locktite on em so they dont fall out again!!!
I bought the 89F350 for parts for my truck... the D60 axle and d/shaft are for of an 89... my truck is a 91. the d/shaft was already pulled when i bought the truck and the seller didn't have the old bolts. I can change it back to a standard d/shaft with out the c/v... I have the d/s and the yolk on the t/c... just like having the c/v.
Thanxs for the replies again... I talked to an old friend at a local auto parts store and he says he can special order any bolt I need as long as he has the dimensions... still going to cost me about 5 bucks a bolt though!
