Sponsored by: Real Truck
F250 Spring Help
Old Jan 7, 2010 | 09:46 AM
brownie83's Avatar
brownie83
F250 Spring Help
hey guys...
i have an 03 f250 with a V10...anyway....my rear springs are getting worn. i would like to get "beefy" ones. i currently have A codes(i think) under spring is XA...assuming X is front and A is rear?? what is the diff between Y codes and A codes. i found a set from an 04 f350, but i want to make sure they will fit, plus they will be better load wise than mine. thanks alot for the help...
chris
Old Jan 7, 2010 | 11:30 AM
spinella's Avatar
spinella
try this link https://www.ford-trucks.com/forums/4...lder_____.html
if it doesnt work look in the tech folder at the top. it should help you.
Old Jan 7, 2010 | 11:36 AM
brownie83's Avatar
brownie83
i looked there first...i just cant find anywhere where it tells the lbs of spring codes
