I was just wondering if there was a way to get rid of the behind the seat tank in my 72? I would like to replace it with one between the rear frame rails like the newer trucks. I guess this is the main reason Ford widened there rear frame in 75. Mine is the narrow stile, 34". Any ideas?
Craig
Craig, Yours is a much batted about question that arises often on this list. I don't think that there is a clear answer for you. You might have to get creative, and I'm sure that you will come up with something. Share it with us when you do.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
You might try a tank that is designed for a '75 highboy. I think a frame tank is available for them, and they have the 34" frame. Ill check my JC Whitney tonight.
I know Ford put gas tanks between the 'rails on some 1973 trucks. My dad has a 1973 F350 super camper special that had a big 'ol tank there - right from Ford's factory. He took it out (was leaking) and gained ground clearance.
My 72 Camper Special came with a tank 23 gal under the bed Between the left frame rail and the drive line. Maby you will find something in the bone yard...
I took a side-mount out of my 68 F250 that had a lot of sludge and varnish inside that I can't get out. I'm not 100% positive, but it looks identical to two (different manufactuers) tanks listed in JC Whitney's 2000 catalog for 73-78 full-size Ford trucks. If it is not exact, I'm sure minor fabrication would fix situation.
