bigger tires
Old Jan 6, 2010 | 09:05 PM
Growl60's Avatar
Growl60
bigger tires
Im getting new tires for my truck next month and I was thinking of going 1-2 inches bigger than stock size. I heard that if you go bigger even by that much that it messes with your speedometer reading and your mpg. is this true? Im a complete n00b when it comes to wheels and tires.
Old Jan 6, 2010 | 11:23 PM
TexasGuy001's Avatar
TexasGuy001
If your truck is a 2wd then get 31 10.50 15. Thats a great size. If its 4wd you can run 32 11.50 15.
The larger diameter tire will cause your speedometer to read slightly slower than your actually going, but not much, unless you have really large tires.
You can reprogram the PSOM if you have a 92-96. If its older you can change the speedo gear.
I didn't see it as that big of a deal with 31s, so I never reprogrammed my truck.
Old Jan 6, 2010 | 11:31 PM
Growl60's Avatar
Growl60
As long as I dont get pulled over im cool. 31s sound like my best bet.
Old Jan 6, 2010 | 11:58 PM
TexasGuy001
I would say that 31s are a good fit. I have them on my truck. Even if my truck was 4wd it would probably have 31s too. The larger tires also can hurt performance since it effects the gear ratio. You speedometer will only be about 3 mph off at highway speed. Thats how mine is.
Old Jan 7, 2010 | 09:24 AM
hav24wheel's Avatar
hav24wheel
so, is it a 4x4, or a two wheeler? Here is my 94 sitting on 33x12.50r15s. Its all stock, with that said, I'm not running the tires yet, as I need to regear.. It is a huge turd with stock gears and 33s.
EDIT: I lied, I did trim the front bumper....
Old Jan 7, 2010 | 10:05 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Im running 33x12.50 and didnt modify anything. Runs good. Only rubs when hard over and just barley
also i have 3.55 gears, and the truck still has plenty of power. Its a 94 Reg cab 351w/e4od.
Gas mileage sucks though. Im thinking there something else wrong with the truck right now though. Thats probably more the reason for the bad Mpg
Old Jan 7, 2010 | 10:08 AM
hav24wheel's Avatar
hav24wheel
BURNSTOUGHFORD, what wheels are you rinning? I have 15x10s with 3.75 inches of backspacing. wheel size and backspacing make a big differance too.
Old Jan 7, 2010 | 10:46 AM
hotrod351's Avatar
hotrod351
i went with the 31/10:50 and im off about 5 mph on the speedometer but my gs mileage stayed the same, 15mpg
Old Jan 7, 2010 | 12:16 PM
Hitokori's Avatar
Hitokori
or u can split the difference ang go with 32x11.5 on 15x10s..... coz evidently 31x10.5 look funny on that size rim
Old Jan 7, 2010 | 01:00 PM
BCHauler's Avatar
BCHauler
If you have the electronic odometer, adjusting for the tire change is easy and straightforward. Just takes a couple of minutes and you don't need tools. There is a how-to on here somewhere, do a search. If you don't recalibrate for the tire change, your mileage calculations will be off, unless you're using a gps or something. I went up to 31's with no complaints. Do recalibrate your speedo. It's fast and easy. The biggest driveability effect I've noticed is that it has lowered the revs on the motor, which is most noticeable to me when accelerating or passing on the highway. It's one reason why I'm contemplating a gear change, but for most users I don't think its that noticeable.
Old Jan 7, 2010 | 02:26 PM
BURNSTOUGHFORD
They are a 8 inch rim , lol i know....
Some sort of American racing i suppose, they have 5 holes and each hole is about 3 inch diameter and they are aluminum.
Blang525
18
May 19, 2013 01:53 PM
ranger505
Jan 5, 2012 02:55 PM
ToledoFire
Feb 27, 2007 12:02 AM
Cheshire Cat
1966 - 1977 Early Broncos
May 9, 2004 03:08 PM
bigdmizer
Apr 3, 2003 04:27 PM
