Arcing RFI problem
Old Jan 6, 2010 | 01:27 PM
GPW200493's Avatar
GPW200493
Arcing RFI problem
Hey all,
I have a 2005 F250 6.0L and it just started to make some arcing sounds every 5 to 15 seconds which is heard on the AM radio and my Ham HF rig from 530 kHz to 50 Mhz and probably higher. It starts off sounding like someone crinckling up paper then it goes into a ripping sound then it's gone for a few seconds to about 15 seconds. I found that this will happen with either the engine running and no engine, but the key in the on position. If the key is in hte acc. position it doesn't happen. Has anyone else had this happen? I also used a portable radio to see if the problem was induced throught the electrical system and found that it was being radiated.
Thanks
Herb
Old Jan 6, 2010 | 03:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Does this happen for MORE than 2 minutes? Check and see.... it may be the glow plug timing circuit.....
Old Jan 6, 2010 | 05:03 PM
GPW200493's Avatar
GPW200493
It happens all the way to and from work....about 15-20minutes wach way.
Rory.jade
Jan 9, 2015 01:49 AM
MountaineerWV
Electrical Systems/Wiring
18
Dec 21, 2013 03:00 PM
RA31925
Jul 20, 2013 09:13 PM
manofsteel52
1997 - 2003 F150
Apr 26, 2010 03:28 AM
Beasty-Fella
1978 - 1996 Big Bronco
Nov 11, 2003 06:49 PM
