1995 explorer 4x4 issues
Old Jan 6, 2010 | 12:11 PM
DOCTAF's Avatar
DOCTAF
sounds like 4 wheel drive is trying to engage itself. major clunking sound in left front wheel. removed drive shaft to rebuild. now a 2 wheel drive. Question is what is causing this clucking engagement issue.
Old Jan 6, 2010 | 04:37 PM
drifter's Avatar
drifter
Could be you need to replace the half shaft on that side.
Old Jan 6, 2010 | 04:51 PM
cmaupin's Avatar
cmaupin
thats what i would look into, they could still turn
Old Jan 6, 2010 | 05:11 PM
DOCTAF's Avatar
DOCTAF
TX FOR THE REPLY. TOOK THE SHAFT OUT STOPPED MY FRONT END VIBRATION ISSUES. HAVING NEW U JOINTS PUT ON IT. I WAS UNDER THE IMPRESSION THE PROBLEM MAY BE THE ACCURATOR OR THE ELECT. 4X4 SHIFT MOTOR. QUESTION IS.. IS THE SHIFT MOTOR AN EXTERNAL UNIT OR IS IT IN THE TRANNY ON A 1995 XLT
Old Jan 6, 2010 | 05:22 PM
cmaupin's Avatar
cmaupin
it is on the back of the transfer case, but that is for makeing it go into 4x4
Old Jan 8, 2010 | 03:16 PM
DOCTAF's Avatar
DOCTAF
thanks again. gonna deal with it when it gets warmer. new problem is heat only on high. any thoughts? blower motor is new and working.
Old Jan 8, 2010 | 09:02 PM
cmaupin's Avatar
cmaupin
Look into checking or replacing the fan switch, local salvage yard is my good friend.
