I have a 97 F350 with a bad 351 engine . I also have an 87 351 enigne that is good. will the intake an fuel injection bolt to the 87 model and/or is this an easy swap?
The 97 is a roller motor , you would need to change the distributor gear from steel to cast to work with the 87 , also i think the heads are better on the 97. ....Lew
The two motors are identical under the intake except for the cam, the '97 having a bigger roller cam versus the '87 flat tappet.. unless the '87 is a factory HO then they are about the same. Does it have a 4bbl carb or 2bbl?
the 87 is carb. but the 97 is efi. will i have any more problem puting the 87 in the 97.
You will need a distributor with advance weights, springs, and a vacuum advance to control your timing.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
