Blinker Problem
Old Jan 31, 2000 | 03:46 PM
dudecorleone's Avatar
dudecorleone
Blinker Problem
I have a 1968 Ford truck. My right blinker comes on but does not blink. How do I get the right blinker to blink?
Thanks,
Bill
Old Jan 31, 2000 | 04:30 PM
HiMe's Avatar
HiMe
Blinker Problem
It's usually just a burned-out bulb that causes your problem. Check all on the right side.
Jim
Old Jan 31, 2000 | 04:35 PM
rick's Avatar
rick
Blinker Problem
Bill, You have one of two problems: 1 being a bad flasher unit, and 2 being a bad bulb, or socket, turn your siginal on and check to see if both front and rear lights are on, if so my bet would be on the flasher unit itself, if one light is not on, I'd start with a fresh bulb, and if that doesn't fix it then your socket there is probably the culpret, you can try cleaning it with a battery terminal brush, or simply replace it, they're not real expensive, and are available at most parts stores, Good Luck, Rick
Old Feb 2, 2000 | 01:56 AM
Jim_V's Avatar
Jim_V
Blinker Problem
