code 31 PFE????
Old Jan 5, 2010 | 08:02 PM
F250-76's Avatar
F250-76
code 31 PFE????
I keep getting code 31. I have replaced the EVP, tested the egr and its working. So I figured it was the egr control solenoid. No go. When I start the truck right about when it drops off of high idle is when it kicks on the CEL?? The only other thing I think it would be is the PFE, but I cant seem to find anything on where exactly it is or how to test it. Looking at napa and autozone etc. online nobody even has a pfe listed.
I check fordfuelinjection.com and cant find anything there either. Any help would be great
Old Jan 5, 2010 | 10:13 PM
F250-76's Avatar
F250-76
from what I can find, they didn't start PFE's until 95 or 96. Haven't checked on the truck yet. Any Idea's
Old Jan 6, 2010 | 01:32 AM
rainbowATF's Avatar
rainbowATF
Check your vacuum reservoir on passenger inner fender for holes from rust damage. The entire bottom of mine was gone leading to leak at warm up. Just a thought.
Old Jan 6, 2010 | 07:14 AM
subford's Avatar
subford
You do not have a PFE (Pressure Feedback Electronic) system on your 1992 F150.
You have the Electronic EGR System.
The Electronic EGR Valve is required in EEC systems where EGR flow is controlled according to computer demands by means of an EGR Valve Position (EVP) sensor attached to the valve.
The valve is operated by a vacuum signal from the EGR-Vacuum Regulator (EVR) Solenoid (9J459) which actuates the valve diaphragm.
As supply vacuum overcomes the spring load, the diaphragm is actuated. This lifts the pintle off its seat allowing exhaust gas to recirculate (flow). The amount of flow is proportional to the pintle position. The EVP sensor mounted on the valve sends an electrical signal of its position to the Electronic Control Assembly (12A650).
Old Jan 6, 2010 | 07:35 AM
subford's Avatar
subford
A code 31 in CM has nothing to do with the EGR Control Solenoid or Vacuum.
The error indicates that the EGR valve was closed further than normal or EVP sensor or circuit has failed with an intermittent low voltage sometime during vehicle operation.
Possible causes:
Poor continuity in EVP harness or connectors.
Intermittent open or short in EVP sensor or harness.
Damaged EVP sensor.
FordCigarMan
29
Jun 26, 2017 08:28 AM
danboy282
Bronco II
Feb 29, 2012 06:35 PM
btorear
Sep 5, 2009 12:27 PM
el conquistador
1983 - 2012 Ranger & B-Series
13
Apr 27, 2004 10:53 PM
doug
Aug 11, 1999 10:45 PM
