Please help!!!!
Old Jan 4, 2010 | 06:52 PM
josh86ford's Avatar
josh86ford
Please help!!!!
my 86 f150, it has an EFI 302, runs fine for about 20 min then starts to bog down like its not getting spark to about 3 cylinders. but i just replaced the cap and rotor. i have no idea what to do. could it have to do with the fuel injectors?
Old Jan 4, 2010 | 07:15 PM
bghnkinf250's Avatar
bghnkinf250
Is it bogging, or dying out? How does it run on the freeway? Two things come to mind - a fuel filter if it is fuel system related (bogging) and these use 2 if I recall, or the ignition module if it is spark related.
Old Jan 4, 2010 | 08:12 PM
josh86ford's Avatar
josh86ford
its kinda both, it boggs down and then will raise back up then down then die. as soon as you put it in drive it spudders and wants to die. when you give it throtle, it, i guess you would say, "garbles" like its under water...sorta speek.
Old Jan 4, 2010 | 09:50 PM
ctubutis's Avatar
ctubutis
Ask the computer what it thinks is up, here's how:
Ford Fuel Injection
