Parking Brake Sensor
Old Jan 4, 2010 | 02:53 PM
mikecox1's Avatar
mikecox1
Where is the parking brake sensor located (the one that controls the idiot light letting you know your parking break is set)? My idiot light says that my break is set but I know it isn't. It is driving me crazy.
Old Jan 4, 2010 | 03:51 PM
alloro's Avatar
alloro
Up above the driver's kick panel nearest the driver's door. If you look in-between the dash and kick panel with a flashlight you should be able to just barely see the switch.
Old Jan 4, 2010 | 06:46 PM
madsonp's Avatar
madsonp
If you depress the pedal all the way, then look at the top of the shaft you'll see a rubber bumper, directly above that you'll see a little brass button with a spring behind it, that's the switch, as shown in the following picture.
Old Jan 5, 2010 | 12:33 PM
mikecox1's Avatar
mikecox1
Thanks guys.
Old Jan 5, 2010 | 12:48 PM
cbradford's Avatar
cbradford
Also low brake fluid will bring on that light, I know on my 97 expy after doing a brake job and bleeding brakes the fluid level went low enough that the float in the master cylinder stuck to the bottom due to the sludge, keeping the light on. Just my two cents.
Old Jan 5, 2010 | 01:54 PM
fordtech08's Avatar
fordtech08
if fluid is low then the red light and the yellow abs light would be on- if they both work
Old Jan 8, 2010 | 10:08 AM
mikecox1's Avatar
mikecox1
I found the switch and it appears to move freely and seems to push all the way back out after being pressed in. I hadn't thought about the possibility of being low on brake fluid, but I don't have an abs light on. I will check thefluid this afternoon just to make sure that isn't the problem. Is it possible to bypass the switch so that the light goes out?
Old Jan 8, 2010 | 10:12 AM
fordtech08's Avatar
fordtech08
yeah there is one wire going to the parking brake disconnect it
Old Jan 11, 2010 | 12:12 PM
mikecox1's Avatar
mikecox1
We have a winner!!!
Thanks cbradford. Low brake fluid was in fact what was making the light come on. I would have never checked that. I thought that light was exclusively for the parking brake. Also, just to maybe help someone out in the future, my ABS light did not come on even though my fluid was low.
Old Jan 11, 2010 | 01:04 PM
fordtech08's Avatar
fordtech08
does your abs light come on when the key is turned on?
Old Jan 11, 2010 | 01:21 PM
cbradford's Avatar
cbradford
Originally Posted by mikecox1
We have a winner!!!
That's what happened to me also that's why I posted that reply to help a fellow out,
Old Jan 11, 2010 | 04:47 PM
cbradford's Avatar
cbradford
But my manual for my 01 does not say if the brake fluid is low that both lights will light, only that after e-brake is released if "brake" light remains on that brake fluid is low.
Old Jan 12, 2010 | 01:37 PM
mikecox1's Avatar
mikecox1
The ABS light does come on when I turn on the ignition.
Old Jan 12, 2010 | 01:41 PM
fordtech08's Avatar
fordtech08
yeah I looked it up some fords have both lights come on when it's low fluid then others just have the red light
Old Oct 27, 2017 | 03:11 PM
zebroski's Avatar
zebroski
Good afternoon Ladies & Gents,
I hate to resurrect such an old post, but this is my exact problem, and I noticed that there is even a picture of the piece that I am missing! Woot!
I have the Parking Brake Engaged warning, along with the wonderful chimes... I have been driving like this for 3 days, and just noticed that I am missing the Rubber Bumper shown in the picture above. If I press the switch in, the light goes out, and the chimes stop... If not... I am being driven slowly insane. Any ideas where I can get one of those rubber bumpers? It is not in my truck, and not in the garage either. I really need to find this before I start thinking the firing range is a good place for this thing!
Thanks!
