head gasket ???s
Old Jan 3, 2010 | 09:52 PM
gbrewer's Avatar
gbrewer
head gasket ???s
I think I'm starting to have a problem with the head gasket on an 87 f-150. I would drive about 2 miles and then would get a slight hesitation like it was running on 7 cylinders. after a few seconds, I would give it a slight increase in gas and it would run fine. After this it would run perfectly the rest of trip of 20 miles. I have not seen any leakage in antifreeze, have always had a slight oil leak for last 30K miles, nothing major. Checked antifreeze, a little low last 2 times, about 1 qt after 2 weeks. No water on dipstick. Oil cap has a thin yellow gunk on it. How likely will I need to replace head gasket? Can bar leak stop this problem? How long will it last?
Old Jan 3, 2010 | 10:37 PM
Conanski's Avatar
Conanski
Don't jump to conclusion, a blown headgasket doesn't usually fix itself it just gets worse and worse. It's more likely you have something else wrong, could be as simple as a bad plug wire or a faulty sensor.
