I am getting ready to replace all injectors, I have at least 3 that are visibly leaking, so I am going to replace all along with a return line kit. 1987 with 6.9 and Banks Sidewinder with 177,000 and what appears to be original injectors and pump. Will I notice increased performance when I replace the injectors, or just wishful thinking? Thanks for you info.
you will see a big improvement.but you could also and more than likely be buying a new ip not long after the new injectors.new injectors are pretty hard on a higher mileage ip.being as injectors and ip are both wear items i would look into replacing both if the funds are available.the ip might be ok but chances are the new injectors will kill it sooner than later
