Radio 12v lt. green/purple + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/black or lt. green/yellow + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on dk. green/purple + radio harness
Notes: This is the subwoofer amplifier turn on lead. The subwoofer and amp are in the driver side rear corner of the cabin. The subwoofer speaker wires are brown/orange (+), and red/black (-) at the radio harness.
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Immobilizer Bypass Module: Required: Yes Type: SecuriLock Part #: 555U
Notes: N/A
I bought metra's 71 and 70 series adapters which do the vehicle and radio side. I solder them together and added speaker wire to the rear channels and a wire for the amp turn on. That extra wire went to a LOC (line out converter) which converts the speaker level signal down to RCAs. From there it's a normal amp install, but I didn't cut any factory wires while retaining the factory head unit.
i am very thankful for all this you saved me about 500.00 dollars thats what they wanted maybe you can help with one more thing i hada fire and am replacing my vac lines but cant seem to find any info on them at all any ideas
