Sponsored by: Real Truck
Fogs not Working
Old Jan 3, 2010 | 12:54 PM
mozzy1234's Avatar
mozzy1234
Unhappy Fogs not Working
Heres my problem on my 07 f350 I installed hids into my fog lights first working fine, yesterday installed hids into the headlights working fine but fogs not working ,been through the systems twice or more everthing is connected and tight,there is power to the fogs but still nothing tried with the engine running but alas nothing so hope someone can point me in the right direction thank alot
Old Jan 3, 2010 | 01:17 PM
TexasRebel's Avatar
TexasRebel
is your ignition on? (Key On Engine Off)
Old Jan 3, 2010 | 01:28 PM
mozzy1234's Avatar
mozzy1234
fogs not working
Hi
Tried with ignition on and off and with engine running and not running nothing
Old Jan 3, 2010 | 01:29 PM
TexasRebel's Avatar
TexasRebel
with the key on, engine off
turn your parking lights on, then pull your switch out to turn the fog lights on... can you hear the relay click?
Old Jan 3, 2010 | 02:18 PM
mozzy1234's Avatar
mozzy1234
HI
yes can hear the relay click is this a sign good or ?M
Old Jan 3, 2010 | 02:22 PM
TexasRebel's Avatar
TexasRebel
good sign...
Can you take a multimeter or a test light to the socket that the bulbs go in?
with the key on, and the fog lights on, you should get a voltage across the terminals inside the connector. (around 12.6v with the engine off)
If this voltage isn't present, check your fuses (actually do that anyway).
Old Jan 3, 2010 | 03:10 PM
mozzy1234's Avatar
mozzy1234
Ok I did what you said no fuses blown but it seems I do not the voltage you quoted with multi its under 10v. does this mean there is not enough fire them up? if so do you have any Ideas as to what be doing this as I said they were fine before I added hids to the headlight thanks alot for your help
Old Jan 3, 2010 | 03:18 PM
TexasRebel's Avatar
TexasRebel
how far under 10?
9.8? 1.5?
do your HIDs have any specs on them? My first guess is that you've burned up the relay or there is some other high current related failure.
Can you verify that the lights work, just not on your truck?
Old Jan 3, 2010 | 03:42 PM
mozzy1234's Avatar
mozzy1234
Hi
First thing voltage looks to be 7v,next I bought these from ddm tuning and DDM HID Kit Slim Ballast (35W 6000k,H13 my sons friend has the same setup and truck and had no problems with them,I will have to take them out to try them on another vehicle or but they were working the night before thks
