heater woes
Old Jan 2, 2010 | 11:30 PM
triskadek's Avatar
triskadek
heater woes
The joy of winter...and very little heat in the cab. I think there is a very slight increase in temp if the dial is twisted all the way to the red.
Engine (eventually) warms up, and there is heat on both of the smaller hoses that go from the cooling system through the firewall to the heater core and back. Both hoses are nice and toasty, so presumably the core isn't blocked, or one would be cooler?
I'm somewhat suspicious the dial to adjust heat isn't actuating the flap that usually exists that lets warmed up air leave the housing of the core. I don't hear any sighing or clunking when twisting it one way or the other.
Anyone know the mechanisms involved behind the cabin temp dial on the dash? (Did I mention I really hate working on anything behind the dash?).
Truck has A/C if that makes a difference. It's my first winter with the ol gal.
Old Jan 2, 2010 | 11:45 PM
Talyn's Avatar
Talyn
this one is easy.
pop the trim piece that goes accross the dash.
Grab a t15 and pull the 2 screws for the bezel.
use the t15 again for the 4 screws, and its out.
take some pictures and check it out on here. I've worked on a few of the setups.
The blend door is actuated by a wire on a rack and pinion.
Sometimes it will jump teeth, but you'll know, cause the dial wont turn all the way.
Old Jan 3, 2010 | 07:37 AM
yoslick's Avatar
yoslick
Next step is these trucks don't make a lot of heat especially idling! Need a winter front for the grill and a 203 degree thermostat with a new water neck, that'll help for sure!
Old Jan 3, 2010 | 09:01 AM
Talyn's Avatar
Talyn
I'm thinking about the new water neck.
It is quite amusing how much heat they make in the summer time, but come winter, they act like they will never warm up.
The filler neck sounds like a good idea though. Supposedly the 94's already had the 203Tstat in them.
Do you have a water neck link?
I'm going to pull my fan off mine actually. Driving down the road, the in dash thermometer is reading far lower than normal summer time driving.
One of the reasons i want to do electric fans, Can just turn them off in the winter time. Cooling systems on our trucks work really good when its cold out. heh.
Old Jan 3, 2010 | 09:10 AM
yoslick's Avatar
yoslick
Heres a good link, look at the very bottom and it'll show a water neck and get you to the right page!!
http://www.dieselsite.com/index.asp?...ROD&ProdID=186
Old Jan 3, 2010 | 12:34 PM
triskadek's Avatar
triskadek
So miserably cold outside I didn't try and take a picture, but the dial is a vacuum control . I think at this point what I want to find is where the heater core is, and if I can just force open the blend door I'll call it good until I can work without the thick gloves on.
Old Jan 3, 2010 | 12:51 PM
helifixer's Avatar
helifixer
remove glove box, remove cover from heater box behind glove box, remove ink pen from blend door re assemble everything.
don't waste your money on a 203 thermostat jut go to ford and get one.
Old Jan 3, 2010 | 01:39 PM
triskadek's Avatar
triskadek
Well, as mentioned ITS FREAKING COLD. Beg pardon, had to get that out of my system.
My fingers weren't adept enough to get the glove box out, but I did hunt around under seat, above where your feet go and below and behind the dash, so it was all visible if I contorted myself.
I can see the plastic housing of the heater core.
Towards the driver's side of the arrangement is a white plastic lever which is actuated by some kind of electric motor. There is a single big green wire going to the back of actuator. I move the white plastic lever by hand and the actuator makes a suction noise.
It occurs to me the big green wire could be part of a sensor, and the actuator is entirely vacuum driven.
I am hoping this white lever is what blends more heat in. I've wedged it open and am about to go for a test drive.
I guess I should fire it up and see if the actuator does anything before wedging it. So annoying to have it vacuum driven in the first place.
Old Jan 3, 2010 | 03:22 PM
Talyn's Avatar
Talyn
The controls should be vacuum driven, but the blend door should be a wire.
I don't see why they would change it for a 97 pickup.
Old Jan 3, 2010 | 04:45 PM
yoslick's Avatar
yoslick
Oh I do, friggin Ford couldn't leave well enough alone, my opinion they should still be making OBS style with the 7.3 !!!!!!
Old Jan 3, 2010 | 05:21 PM
triskadek's Avatar
triskadek
So. The good news is the white plastic lever attached to the actuator is in fact the blend control lever. I wedged it open and magically the cabin is heated!
I am still unclear about the actuator itself.
Testing if the actuator or the vacuum lines or the dial controller are the problem will be a PITA I'm sure, but for now I have heat.
Old Jan 3, 2010 | 09:14 PM
Talyn's Avatar
Talyn
Sounds good for now. Wait till it gets warm to mess with that stuff. its tight and need finger bendage.
Old Jan 3, 2010 | 09:45 PM
95_Dually's Avatar
95_Dually
I have read this on here before. Perhaps from you. Anyway, this just might be his problem. Funny post too. Thanks, I am still laughing.
Old Jan 3, 2010 | 10:07 PM
triskadek's Avatar
triskadek
Hahah I only just figured out the pen...Yes if only it was that simple, but I am _never_ that lucky.
What I'm really wondering now is WTH is the thing I'm calling the actuator. As far as I can tell from pictures and diagrams I've found on the 'net, the actual actuator (pardon I couldn't resist) is up higher, and you must remove the glove box to see it.
The thingus I found attached to the white plastic lever I wedged open looks nothing like the actuators in the pics. Mine is cylindrical with a rubber boot where it actuates the white plastic lever. I think the vacuum hoses lead in to it, but I really need to verify that (when it is warmer or at least not snowing). It definitely has a relatively heavy gauge green wire connected to the back.
The actuaters in the pictures are rectangular boxes, appear electrical only, and apparently have a penchant for busting on the keyed end. There is a cheap fix to make your own new key with a filed nail. I like cheap fixes.
Old Jan 3, 2010 | 10:49 PM
helifixer's Avatar
helifixer
not sure what that pod is but on all the obs trucks I have done heater / ac work on the blending door is operated by a wire running from the temp control to the blend door. if I get time in the morning I will look at mine and see if I can figure it out
