1978 - 1996 Big Bronco
stumped???? thumping/growling
Old Jan 2, 2010 | 05:59 PM
dumbear33's Avatar
dumbear33
I just bought this bronco yesterday its a 95 with low mileage, I bought it with the problem of a intermittent thump and growling coming from the behind the seat area. My first thought was a bad wheel bearing in the rear axle so today I tore into it...everything in the rear diff looks good, it had clean oil and no metal or chunks. I pulled the axles which both sides have very little up/down play, the bearings look good not burnt and rotate freely with no catches that I can find.
Now here is what has me stumped, before tearing down the rear end I put both rear wheels off the ground put the truck in neutral and attempted to turn the wheels and boy was it tight. I actually had to use a breaker bar to turn the wheels.
Should I suspect a bad transfer case? it engages fine and disengages fine no problem could a rear output bearing cause this?
Any tips for checking is greatly appreciated.
Old Jan 2, 2010 | 06:54 PM
kenpobuck's Avatar
kenpobuck
Check the doublecardone joint (the double u-joint) on the front of the rear drive shaft.
Old Jan 2, 2010 | 06:56 PM
deadeyedevon's Avatar
deadeyedevon
maybe the slip yoke is burnt up? just a guess
Old Jan 2, 2010 | 07:47 PM
helirich's Avatar
helirich
How about disconecting the driveshaft at the diff and see if the wheels/shaft turn eazy?
Old Jan 2, 2010 | 07:52 PM
deadeyedevon
good idea,prosess of elimination
Old Jan 2, 2010 | 09:52 PM
dumbear33's Avatar
dumbear33
I'll give those ideas a go tommorrow, although I would be surprised if its a U joint their is no clanking when I engage reverse to drive several times. but it doesn't hurt to physically check them for binding and stiffness.
thanks guys
Old Jan 3, 2010 | 04:11 PM
dumbear33's Avatar
dumbear33
Well looks like it may be a bad universal joint at the rear axle it has a little bit of play in it plus it looks like Ford originals. I'll replace all 3 joints and post my results.
Thanks Guys for the tips
Old Jan 4, 2010 | 12:43 AM
greystreak92's Avatar
greystreak92
Make sure if you replace the double cardon spiders that you replace the centering ball and spring as well. These two components will come out when you pull the spiders anyway.
Old Jan 4, 2010 | 01:23 AM
MDM123's Avatar
MDM123
I hate to sound uneducated, but did you look to see if your parking brake isn't snagging?
Old Jan 4, 2010 | 02:44 AM
g_k50's Avatar
g_k50
Parking brake engaged, Hahahahaha, good one.
Old Jan 4, 2010 | 11:32 AM
Kemicalburns's Avatar
Kemicalburns
i would also confirm that your tcase is full of fluid. also did your rear diff have a Limited Slip? if so you need to add some friction modifier to the gear oil otherwise you will thrash that LS quickly.
YellowXLT
Mar 6, 2020 06:16 PM
rustynuts
Apr 23, 2018 06:03 PM
timbersteel
Sep 30, 2016 04:31 PM
Baatzy
May 3, 2015 05:01 PM
MadRabbits
Sep 1, 2003 11:49 PM
