48 progress pics
Old Jan 2, 2010 | 03:08 PM
Wayne S's Avatar
Wayne S
48 progress pics
We sanded on the cab all day yesterday.Just a few minor touch up and we will be ready to spray.
Old Jan 2, 2010 | 03:27 PM
56panelford's Avatar
56panelford
Looks good. I'm hoping to be there some day too, are you painting the inside at the same time or doing it in steps. I'm still trying to figure the procedure.
Old Jan 2, 2010 | 03:38 PM
Wayne S's Avatar
Wayne S
Inside is already painted.Going to undercoat what is not painted.
Old Jan 2, 2010 | 03:42 PM
Wayne S's Avatar
Wayne S
And another
Old Jan 2, 2010 | 04:24 PM
daves54's Avatar
daves54
good luck with the project cab looks great!
Old Jan 2, 2010 | 07:31 PM
WALFORD'S 56's Avatar
WALFORD'S 56
Looks like it will be sharp when you are done.
I have done many.....and it is exciting to see your OWN paintwork....and say..I PAINTED MY OWN TRUCK.....Cool.........Bill
Old Jan 2, 2010 | 07:52 PM
51PanelMan's Avatar
51PanelMan
Looks like you're using a 51/52 cab on your 48 project?? Will be a morph.
Old Jan 2, 2010 | 08:11 PM
Wayne S's Avatar
Wayne S
That's correct 51 cab. I liked the dash and the larger rear window.Also using a 51 hood because of the side hood vents.
Old Jan 2, 2010 | 08:51 PM
51PanelMan's Avatar
51PanelMan
Did you modify the hood to accept the spring from the 48-50 upper valance panel (the piece between the upper fenders above the grille)? If not, then you'll either need to modify the hood or get a 51/52 upper valance panel. I'd get the 52, because it has the FORD letters in it just like the 48-50.
The spring is on the upper valance in a 48-50 and on the hood in 51/52.
48-50 upper valance
51 upper valance (6 cyl)
Latch (same as in 51/52). Also note the V8 emblem. This is for 51 only. The 51 equipped with a 6 cyl didn't have an emblem (see above).
Here's another shot of a 51 with 8 cyl. Note the two holes for the "V8" emblem.
Here's a 52. Hard to see, but the best that I could come up with through my images.
Another 52 from my truck (6 cyl emblem on hood, same place where a V8 emblem would go).
I hope that you already knew the difference. Didn't want you to go through the trouble of painting everything, then not being able to shut your hood and having to redo everything again.
abusek
Sep 26, 2016 08:43 AM
Harley48
Large Truck
26
Sep 14, 2016 10:25 PM
Cody_1948
May 16, 2014 07:10 PM
mytbtruck
Jul 1, 2012 08:13 PM
