Coolant leak
Old Jan 2, 2010 | 10:48 AM
Ajc11892's Avatar
Ajc11892
Coolant leak
hey, this is my first thread, i have a 1994 <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_0_0>F150</NOBR> 4x4 with the 302ci V8, i have a coolant leak, and i think its the freeze plugs, or the head. I tried heavy duty stop leak in my radiator but that obviously didnt cut it considering theres still a coolant puddle left where ever i park a week after i put the stop leak in. Anyone have an idea of how much it would cost to get the freeze plugs fixed, or the heads fixed, depending on whichever is leaking once i find out what it is. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Jan 2, 2010 | 11:27 AM
aaron_sk's Avatar
aaron_sk
No stop leak. Don't run that garbage. Do a flush as soon as you can and your heater core and water pump might survive.
Freeze plugs are cheap. Pound them out with a screwdriver, pound them in with a big socket. The problem is getting to them.
You need to crawl under there with a torch and find out exactly where the leak is coming from.
Old Jan 2, 2010 | 11:28 AM
quicklook2's Avatar
quicklook2
have coolant system pressure tested before you start tearing things up.
