Newbie with important question?
Old Jan 2, 2010 | 12:56 AM
Shepherd Taxi's Avatar
Shepherd Taxi
Hi Diesel Guru's.
I was told to post this question here so I will do so. I am in a bind and I need to know what tool is needed to remove the "Idle Pulley" from my 93 F350? It is a right hand thread is it not? Any info would be very much appreciated
Thanks
Shepherd Taxi
Old Jan 2, 2010 | 01:00 AM
rupejosh's Avatar
rupejosh
welcome to FTE and the pre-powerstroke forum.
if i remember correctly when i did mine it was a torx bit not %100 though and am not sure if its right handed or not.
Old Jan 2, 2010 | 09:26 AM
PLC7.3's Avatar
PLC7.3
Torx 50 normal RH thread rotation (lefty losey)....... the only one with a reversed LH thread is the 15mm pulley bolt on the tensioner.
Old Jan 2, 2010 | 09:33 AM
LMS Residential's Avatar
LMS Residential
subscribed.....
Old Jan 2, 2010 | 03:33 PM
Shepherd Taxi
Thanks Guru's for your help here. I used the torx 50 and she came out just fine. What I have found out in looking for the part is, do I need an outer lip on the "Idler Pulley". The one that blew almost looks like a pulley for a "V belt". Grant you it is very damaged.
I think that I can get away without it for that is what was on it from the factory according to the Ford people when they look up my vin number.
Thanks Again for the help,
Shepherd Taxi
bone_collector
New Member Introductions
Jan 31, 2014 04:16 PM
Shepherd Taxi
111
Jan 21, 2010 09:59 PM
Shepherd Taxi
15
Jan 7, 2010 10:08 PM
LaredoF350
24
Jan 20, 2007 08:28 AM
LaredoF350
Jan 19, 2007 11:32 PM
