It seems every year when the weather first turns cold I have performance issues with my 2007 6.0. Back in October I started running double doses of Howes anti-gell. Done this for the next three tanks and then took it in and had the oil changed and the fuel filters changed. As usual it seems first cold spell where the temps dropped into the high single digits and low teens the truck started to have performance problems. No power when trying to pass. Pedal to the floor and topped out at 55-60 MPH. Losing speed and RPM on long up hills. As long as I did not push the engine it would run as fast as I wanted as long as I eased into the throttle. Stomp down on it and nothing. Took it to the dealer and he checked it out. Tech was driving it with a laptop hooked up and it was running fine and then the fuel pressure dropped to almost zero and then recovered. Further testing revealed nothing amiss. They have told me that they think I must have gotten some bad fuel. What is bad fuel anyway? Buy my fuel from BP stations that sell a lot of fuel so wonder how likley that is. Any thoughts? Are they just telling me we do not know what happened so it must be bad fuel?
Bad Fuel? Water,sludge,rust.... what are they telling You it may be? Sounds as if You might want to pull your EGR valve as well as changing your fuel filters. Clean the EGR valve and change fuel filters, check or replace Air Filter as well.
If it is bad fuel make BP pay for any repairs. Last Dec08 had fuel problem with Quick Trip diesel and repairs were $600+ and QT paid the repair, don't know what policy BP das for paying.
I think it's the howes that's doing it...
I started running Howes a few weeks ago and have recently stopped becuase it really brings my truck down. Even with my DP-Tuner I noticed my fuel economy suffering and my engine sounding sick. I ran the tank empty and filled up with straight diesel and my truck was it's normal self again. My fuel economy and power have since improved also.
Try running the tank down like I did and using straight diesel from the pump. Only fill it up to quarter tank and see how it drives, if performance improves, it was the Howes, if not, it has to be something else.
Try the Powerservice Diesel Kleen white bottle Anti-gel. It's readily available at wal-mart and most parts stores.
Call the supplier of the fuel where you normally buy your fuel. Ask what they have their fuel treated to. Then watch the weather, colder, add anti-gel.
For peace of mind, add anti-gel of your choice all winter, no need to double dose. The Pilot TS I fuel at is currently 0f. If I'm going to Central Oregon, I add anti-gel, cause it can get below -10f pretty quickly. When in Central Oregon, I try to fuel at the Pilot in Chemult, Oregon, Theirs is treated to -25f.
It sure sounds like the fuel filters need changing. Example: I changed our fuel filters just before leaving on vacation. Went around 1K miles lost power while towing. Had the filters changed and had mega power. So i got some not clean fuel from a truckstop somewhere.
