first tire rotation
Old Jan 1, 2010 | 03:42 PM
ghoyt87's Avatar
ghoyt87
first tire rotation
I have a 2009 fx4 with the tow package and the 18' wheels...
I am just curious how much i should torque the lug nuts down...
Thanks
Greg
Old Jan 1, 2010 | 04:09 PM
shotgunz's Avatar
shotgunz
Check your manual. I believe it's 100 ft-lbs.
Old Jan 1, 2010 | 06:00 PM
ohboy44's Avatar
ohboy44
The correct torque is 150 lb-ft
The kicker is you will need to have the TPMS sensors retrained for their new positions.
Old Jan 1, 2010 | 06:18 PM
johnwill's Avatar
johnwill
I'm with you on the 150, but are you sure about that TPMS bit? I know yes if front and rear tires are diff pressures, but I think otherwise (from my own experience), if front and rear same pressure. Are you saying retraining needed in all cases? Thanks
Last edited by johnwill; Jan 1, 2010 at 06:22 PM. Reason: I had a booger on my nose, sorry.
Old Jan 1, 2010 | 06:27 PM
shotgunz's Avatar
shotgunz
Yeah - 150 ft-lbs. is correct. Teach me to go from memory.
John, you're correct about the TPMS. It doesn't need to be retrained unless front/rear have diff. pressures.
Old Jan 2, 2010 | 04:17 PM
ohboy44's Avatar
ohboy44
It does make a difference when or if you have a problem with the sensors and the person checking it out replaces the wrong sensor.
I know the service manual recommends retraining after tire rotation.
I've heard that the reset tool from Ford is less then $20.00 might be worth getting one to save any hassle.
Old Jan 2, 2010 | 04:25 PM
ghoyt87's Avatar
ghoyt87
Does the manual tell you how to retrain them?
Old Jan 2, 2010 | 04:39 PM
johnwill's Avatar
johnwill
Yes. Only need to get and use if diff pressures on front and rears. Trucks that shipped as such had the tool included.
Havecooker
Apr 9, 2017 11:07 AM
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
jasonschwenk
New York Chapter
Nov 27, 2006 07:35 AM
