Blower Motor
Old Dec 31, 2009 | 11:09 PM
79FordBlake's Avatar
79FordBlake
Blower Motor
Drove my 79 Bronco to gas station today to fill up and stretch it's legs. On the way back I started smelling something that was burning then the heater stoped blowing. I think the resistor burnt up as I only smelled the burning coming out of the vents and no where else. For now can I bypass the resistor and it just run on high? I just want to make it through winter for now. I only drive it to stretch it's legs some and when the weather is bad, other than that it sets.
Old Jan 1, 2010 | 01:59 AM
Riderman's Avatar
Riderman
Typically, high is all you get when the resistor pack blows. High blower speed is without any resistance. Check your heater fuse, switch, and blower motor, then wiring...If you think the resistor pack is the problem, take the large supply wire (orange?), make sure it has 12 volts with the switch on, and connect it directly to the wire going to the blower motor.
