I am looking for a replacement engine
I am at the point of no return with my engine. It has left me stranded again. I love the truck but have no faith in this engine. It has broken and bent things no one has heard of (like 5 pushrods on 4 different cylinders).I have a line on a brand new 03 engine, complete except for FICM. I know there are many differences in the 03 and 04. My questions relate to interchangebility of some parts. Will my FICM work with this engine? What about the differences in the HPOP and the ICP locations? The turbo? I have a FCD egr delete on my current engine and a brand new oil cooler. Are there any differences between the oil coolers/filter assembly? If I do not go this route, I will look for a 06 used engine. What issues will I find with that scenario? I looked at Bismics list and did notice some fuel line changes and radiator hose location differences? Help please?
You need to find out id the o4 engine is early or late build.
just wondering does your truck sit alot?
I was pretty sure I could count on your help. My truck engine is a late build 04 with the IPR sensor on the valve cover and it had the 04 style egr cooler that I deleted. The truck does not sit much when it runs.It had 97000 miles on it when I bought it. I put 20000 miles on it from early this May when I bought it until September. I did an Oasis on it when I purchased it and actually talked to the dealer who sold it new and took it on trade. He had wholesaled it to the used dealer I bought it from. It had received regular scheduled maintenance and the only warranty was a new turbo just before it was traded. I had an egr cooler failure at 104000 miles. I deleted the egr cooler at that time. The oil cooler failed at 118000 miles. I replaced it and did head gaskets and ARP's. I had the heads redone at a very reputable shop. I had a lot of issues getting the coolant cleaned and other issues resolved but perservered. I still do not know why it bent 5 push rods. I put 1100 miles on it and it ran fantastic. Then it just quit. When I tried to restart, it ran very poorly, belched blue smoke and quit. I could not restart it. When I got it home I found the starter had lost a bolt, came loose and brokr the starter case. Now I am just plain scared of this engine. I love the truck. It pulls my 12000 pound fifth wheel real nice. I just need it to run.
Thanks for all your contributions here
however you could use the whole wiring harness and may be allright. Im not 100% on this though. another option would be to overlay the harness to the icp sensor new location and thats easy enugh.
Im sure ill think of more on this as the topic grows.
There were issues with this engine early on when with sitting to long and lifter's pumping up and getting stuck also a few with buildup on the vaves and they will stick after sitting for some time.
We have had a few that will pump up lifter when you pull the heads and bend the push rods when you start it up.
The push rod problem was exactly as you described after HG replacement. I did replace 2 lifters before it quit bending them. We have it partially apart now and do not see any bent push rods. I definitely have the new style "wavey" oil rails. Do you think a low milage, under 60000 miles, 06 engine would be a better route to go? I worry about the early HPOP pump issues. Whatever goes back into the truck, it will have reconditioned heads, new head gaskets,ARP studs, egr delete, the new oil cooler from current engine and a coolant filter. I have read that 06 and up engines have been relatively problem free. I bought the truck at a really good price so I can justify fixing it right.
Thanks again,
Thanks for the offer. I am looking for a lower mileage runner that I can basically spend a day or so doing the upgrade mods and then install it.
remember with all engine swaps even the easy ones there is bound to be some issue
In many jurisdictions, that mean you cannot get the vehicle smog passed if they know about it.
If you are going this route, why not buy a reman from a reputable place near where you are?
Price is close to the same as buying a used engine of unknown reputation...
remember Im a dealer tech and dont get much in to the mods and incorect year motor swaps much. someone on here no doubt has some more info.
Your choice. EGR deletes can be undeleted anytime.
But if you are nailed for a non compliant engine, the fix is to put in a compliant one.
