vacuum advance source
Old Feb 29, 2000 | 08:51 PM
bdowens3's Avatar
bdowens3
can anyone tell me where the vacuum line for the distributor advance should go? idle vacuum or venturi vacuum. i have a 74 ford with 390 ...thanks in advance
Old Feb 29, 2000 | 08:59 PM
oleblue70's Avatar
oleblue70
venturi vac.i'm sure you know how to find that port.you know how you unplug your vac advance when you chech your mech. timing?that tell's you vac advance is off idle.mechanical is checked w\ no vac advance..blue
Old Feb 29, 2000 | 10:41 PM
STROKER's Avatar
STROKER
