Sponsored by: Real Truck
Fuel Leak
Old Dec 31, 2009 | 02:49 PM
Loopy's Avatar
Loopy
Fuel Leak
I'm not sure if anyone has had this problem with their Super Duty, but I seem to have a fuel leak at the top of my gas tank. It only leaks when I top off the tank. Not sure if there is a gasket that seals the tank or what. Thanks for any input.
Old Dec 31, 2009 | 03:06 PM
senix's Avatar
senix
are you overfilling it...right up to where you put the cap on?
Old Dec 31, 2009 | 03:20 PM
Loopy's Avatar
Loopy
No. I was able to top off the tank back in the summer and the tank reading on the console was around 330-350 miles till empty when it wasn't leaking. Now it leaks at the tank and the reading is down to 260-290 till empty. I didn't think it would leak at the tank as an overfill.
Old Dec 31, 2009 | 03:35 PM
senix's Avatar
senix
the reading is indepent of what is actually in the tank. The PCM is taking your driving habits and actual mpgs and calulating how far you can go.
so do you see a leak somewhere around the tank area?
Old Dec 31, 2009 | 05:46 PM
Loopy's Avatar
Loopy
I can't see where it's leaking, but I can feel gasoline where the filler tube enters the tank.
Old Dec 31, 2009 | 06:06 PM
bpounds's Avatar
bpounds
The top of your tank looks something like this:
So you need to find where it's leaking. Could be the hose clamped fill or vent lines, could be the big bung nut, could be the supply or return lines. Could even be a air vent tube cracked or pulled off. You might be able to figure it out and fix it by reaching up in there, but probably not. Easiest is probably to lift the bed off and inspect the top side of the tank. You can drop the tank instead, but it will be easier to identify a leak if you have not disturbed the lines in the process of dropping it.
Old Jan 1, 2010 | 12:48 AM
Loopy's Avatar
Loopy
Wow. Thanks for that pic. Here's a question. Is that a rubber type grommet that the front air vent is connected to? There is a tube hanging from above the tank that has a plastic end coming out of it. That may be the culprit.
Old Jan 1, 2010 | 05:46 AM
senix's Avatar
senix
that is rubber. If that is what needs to be replaced or fixed then make sure you get the proper type of rubber compatible with fuel.
Old Jan 1, 2010 | 09:05 AM
bpounds's Avatar
bpounds
All the fittings into the tank are glued in place and cannot be regasketed. The only removeable item is the big nut where the sending/pickup unit is installed.
I think what you are asking about is a TEE fitting in the air vent. I believe the little stub that sticks up is a check valve that is supposed to let air in, but not let fuel out. But I'm not certain on that. It's probably not very expensive to replace. BTW, there is another one just like it on the other end of the tank that isn't shown in that picture.
You can find some more pictures here:
Powerstroke Fuel Tank Modification
Just remember that this is a diesel tank, and you cannot make that modification to a gasser. But the tank itself is the same thing. The plumbing may be a little different because you have a charcoal vapor system.
Old Jan 1, 2010 | 09:23 AM
Loopy's Avatar
Loopy
Thanks for the info guys.
ndeidrick
Sep 15, 2022 10:05 AM
dondolittle2
6.4L Power Stroke Diesel
Oct 3, 2016 01:38 PM
Str8shooter
6.7L Power Stroke Diesel
Jul 21, 2012 12:58 AM
ligito
Nov 10, 2010 07:52 AM
birddog16
May 15, 2007 02:54 PM
