Shifting into Park ?
Old Dec 31, 2009 | 02:16 AM
George Frasier's Avatar
George Frasier
Unhappy Shifting into Park ?
JUST took delivery of an '04 Explorer. Runs fine & such - BUT - The column shifter indicater is 1/2 way to the right of a selected gear, and it is sometimes hard to start without fiddling with the shifter. Once we parked it on a slight incline and got out - a few feet away it "ratcheted" and rolled a few feet till the pawl took hold. I was wondering if it might be a simple fix ( something jammed in the linkage), an adjustment, or a real problem. ?? EDIT / 1-5-10 = 2000 Explorer - in dealership shop for trans "adjustment.
Old Jan 1, 2010 | 11:27 PM
Rangerman Stan's Avatar
Rangerman Stan
Sounds like a shift cable/linkage adjustment problem. If you got it from a dealer, take it back and have them adjust it to make it work correctly. If you got it from private seller then you would have to take it to a trans shop to get it adjusted. I hope you can get it worked out.
Old Jan 2, 2010 | 05:30 PM
deadeyedevon's Avatar
deadeyedevon
second that, i dont believe its a big deal to have a tranny shop fix it, if you got it from a dealer then its no cost at all(most have atleast a 30 day waranty0
Old Jan 2, 2010 | 06:49 PM
aquanaut20's Avatar
aquanaut20
You should not rely on the park pawl to secure the vehicle, it is a soft metal tab about the size of a pencil eraser.
Old Jan 2, 2010 | 07:58 PM
deadeyedevon
i preach that to the wife twice a week
r-kid
Mar 4, 2014 11:12 PM
mrberg89
Nov 10, 2012 10:45 AM
Eric_F250
Feb 18, 2009 04:26 AM
kupaa
Sep 20, 2008 12:20 AM
