steering wheel problem.
Old Dec 30, 2009 | 04:51 PM
brians1979f100's Avatar
brians1979f100
I have an aftermarket grant GT steering wheel on my f100 from the previous owner. The horn button sticks and the auto return for the blinkers are broken. also the wheel rubs the collum and squeeks when i turn the wheel, It is very annoying! so i was starting to look into aftermarket wheels and such. well i am in the process of removing the wheel and it will not come off... i removed the allen screws and slapped and yanked and no dice...is there a bolt under the horn button if so how is the horn button removed? it does not seem to come straight off. so if anyone has a grant steering wheel and can shoot me in the right direction on what to start with please chime in. also what are some good steering wheel options besides grant?
Brian.
Old Dec 30, 2009 | 05:00 PM
zak8tac's Avatar
zak8tac
Yes put back in the allen screws. Take a small flat screwdriver and pry the horn button off. Make sure to disconnect the battery. Once the horn button is off you will see why it is sticking (there is a large spring underneath it to return it). You will also see the rather large nut holding the wheel to the column. There are three screws holding the steering wheel to the mounting bracket. Take these off. Steering wheel comes off and your left with the small three legged star bracket that is bolted to the steering column. You will need a steering wheel puller to get this off as its is a compression fit. Pull the nut off and then hook up the steering wheel puller to get the bracket off. OR you could just buy a new Grant wheel you like and re-install using the same bracket. Or just fix the problems with your current wheel.
Oh and with the grant wheels, unless you install the adapter plate to make the blinker cancelers work they do not work
Old Dec 30, 2009 | 05:09 PM
brians1979f100
Thanks for the Info. when i pry the button off will it damage it or will it be fine? ill order a new one if need be but i just need a horn..
Old Dec 30, 2009 | 05:14 PM
zak8tac's Avatar
zak8tac
It shouldn't damage at all, there are little tabs on it designed to "pop" in and out, only thing else in there is a spring and the grounding disc with the wire attached to it. Worst case that would be what you damage but just be easy everything should be fine. If your horn doesn't work make sure the area it grounds to is clean. It works off of grounding three little "feet" to the inside of the steering wheel. If the steering wheel is a painted surface the kit gives you a foil like sticker to put on the inside to aid grounding
Old Dec 30, 2009 | 05:18 PM
brians1979f100
also how do i find out the spline count??
Old Dec 31, 2009 | 12:12 AM
Dirt racer's Avatar
Dirt racer
I run a grant wheel on my 75 -F100 4x4. To remove the horn button, disconnect the battery or the horn and I press it all the way down and turn it and it should come off. Otherwise do what Zak8tac said and it shouldn't hurt it. Mine also had the big nut and 3 small bolts holding it on. You will need a puller to get the inside piece off to access your turn signal switch. Probably the plastic cam piece is broken. I think most parts stores sell these. I replaced my whole turn signal switch a few years ago and bought it from the local ford dealership. I think it was around $60 then. For the squeaking I ground some metal off the cup piece that goes under the steering wheel. That is where mine was rubbing. I also cut the turn signal lever shorter and rethreaded it for more clearance especially when wearing gloves.
Old Dec 31, 2009 | 09:44 AM
zak8tac's Avatar
zak8tac
underneath the horn you will be able to count the splines. I however do not know what the number is off the top of my head.
Old Brown Truck
Nov 13, 2014 01:11 AM
Green72F250
Jun 26, 2014 02:40 PM
F350moneypit
19
Feb 4, 2013 01:46 AM
ffillah
Sep 5, 2012 01:18 PM
1978fordf250
15
Feb 10, 2006 05:17 PM
