Block heater trouble
Old Dec 30, 2009 | 02:54 PM
sdunn's Avatar
sdunn
block heater working one day and not the next works about once a week sometimes wont work for weeks then works great and suggestions any pics for trouble shooting much appriecated
Old Dec 30, 2009 | 03:07 PM
snakedoc's Avatar
snakedoc
i would look for a broken wire around the bumper or near the heater.
Old Dec 30, 2009 | 03:15 PM
Ponyboychris's Avatar
Ponyboychris
A common area of wear is at the male plug end at the bumper. Check for a break in the wiring.
Old Dec 30, 2009 | 03:23 PM
BillyBob69's Avatar
BillyBob69
What they said. The cord that is put in there from the factory doesn't take alot of abuse. Start checking from the plug and go back.
Old Dec 30, 2009 | 03:26 PM
sdunn's Avatar
sdunn
i started at the heater and that has a red cord on it when i get to the front it is a black cord wrapped in plastic could the connection from red to black be shot?
Old Dec 30, 2009 | 03:30 PM
BillyBob69's Avatar
BillyBob69
Could be or the copper wiring itself inside the insulation could be broken...especially at a bend.
Ponyboychris
I don't remember offhand anyone finding a problem there but I could be mistaken. The most common area is right behind the plug. The cord has the tendency to dangle and rub on the edge of the bumper or if you or the previous owner drove off with it still plugged in, then that's where the stress on the wire occurs.
Old Dec 30, 2009 | 04:17 PM
sdunn's Avatar
sdunn
just replaced the plug end... waiting to see if it heats up... can u buy factory plug from heater to front of truck??
Old Dec 30, 2009 | 04:23 PM
andrewc53's Avatar
andrewc53
You can go to any hardware store and get a outdoor plug and some #14 wire and splice it back by the heater. Cheep fix if it
s not the element. A Curtis
Old Dec 30, 2009 | 04:28 PM
sdunn9's Avatar
sdunn9
how often do the heating elements go bad??
Old Dec 30, 2009 | 04:57 PM
Ponyboychris
Not often. Most of the time it's the cord end.
Old Dec 30, 2009 | 05:03 PM
big poppa's Avatar
big poppa
Just make sure you get it fixed up right, with the same gauge wire and such, a fella here had his truck destroyed from a faulty wire or connections. After the fix, just to be safe, park your truck away from any structures for a couple days and check it again.
Old Dec 30, 2009 | 07:00 PM
sdunn9's Avatar
sdunn9
i just replace the plug in the front of the truck, i didnt splice anything back near the heater.. do i have to worry about destroying the truck by doing that...???
Old Dec 30, 2009 | 09:00 PM
Rushmore X's Avatar
Rushmore X
Should be able to check it with an OHM meter? Anyone know what it should read for resistance? thanks
Old Dec 30, 2009 | 09:02 PM
Rushmore X's Avatar
Rushmore X
Welcome to the forum by the way...
