Performeance
Old Jun 28, 2010 | 11:39 PM
SofaKingBest's Avatar
SofaKingBest
Originally Posted by lew52
Well a good tune up to start with , something you can do for free is advance the base timing a few deg from 10 to 12-14 BTDC , Next would be long tube headers & exhaust . You don't want to spend alot of money , so i would look for something like the HO cam & GT 40 heads , look on craigs list ect , you should be able to find them cheap . Rear end gears will help to ....Lew
Would these items work on a 89 351? What about a K&N filter setup?
Old Jun 29, 2010 | 01:22 AM
FireBlue's Avatar
FireBlue
It is still a good idea to advance timing on the 351W? how much by? cheers
Old Jun 29, 2010 | 04:46 AM
lew52's Avatar
lew52
,,,,Yes As much as it will tolerate with out pinging under load , around 14 or so ...
Old Jun 29, 2010 | 04:48 AM
lew52's Avatar
lew52
....Yes they will work , if you use the K&N i would use the drop in filter...
Old Jun 29, 2010 | 11:36 PM
SofaKingBest
Post
Ok what year HO cam am I looking For? And what about using short headers? Where do I find the upgraded Y pipe? Are the Summit Racing cat-back mandrel bent kits good?
Old Jun 30, 2010 | 12:18 AM
TexasGuy001's Avatar
TexasGuy001
If you go with a KN filter just get a drop in replacement. Whatever you do don't waste your money on FIPK hot air intake nonsense. I had one and it was the biggest waste of money I ever spent.
In my opinion your better off with a regular filter and the I6/460 lower intake tube. If your set on a reusable filter the AFE or AEM dry flow filters are worth looking at. I would stay away from oiled filters.
Old Jun 30, 2010 | 12:26 AM
SofaKingBest
Explain I6/460 lower intake Tube?
Old Jun 30, 2010 | 12:31 AM
TexasGuy001
The 300 and 460 got a different tube than the 302 and 351. It pulls air from behind the grille next to the headlight instead of up on top of the radiator.
Old Jun 30, 2010 | 06:15 AM
lew52's Avatar
lew52
....Around 88 and up on the HO cam , the cat back is fine , you should be able to get the y pipe from summit to ,shorty headers are ok , you will get a little more from long tubes and you would need custom exhaust...Lew
Old Jun 30, 2010 | 06:24 AM
lew52's Avatar
lew52
On the 89 351 the block needs to be roller ready ? , you would need the cam & liffters spider & dog bones from a roller motor....
Old Jun 30, 2010 | 09:16 AM
Conanski's Avatar
Conanski
The 351/5.8 block did not become roller ready until 1994 so earlier blocks will not accept the factory roller assembly without machine work. If you want to use a roller cam in an early block you need linkbar roller lifters which can be expensive... like $500 a set, it's much more cost effective to simply use a better flat tappet cam like the Crane 444232.
Old Jul 28, 2010 | 12:49 AM
SofaKingBest
Start with
Now I found a y pipe cat set up on ebay Davico CATALYTIC CONVERTER ford F-250 94 93 92 91 90 89: eBay Motors (item 230498619638 end time Aug-12-10 05:44:36 PDT)
Would this be an upgrade or just parallel movement? As for short headers would the summit brand be acceptable? Any recomendations on which muffler to choose. Stock is too quiet but not looking for snapping and popping when accelerating.
Old Jul 28, 2010 | 05:08 AM
  #28
lew52's Avatar
lew52
I don't know about that y pipe , never heard of them , summit racing has alot of exhaust pipes , i think magnaflow & flowmaster & others make a y pipe for it . The summit headers should be fine , i like the coated headers , they will hold up better , mufflers are your choice , if you don't want the popping & blairing loud i wouldn't use glasspacks...Lew
Old Jul 28, 2010 | 09:39 AM
  #29
J1nx93's Avatar
J1nx93
I have a K&N filter in my truck, would you say this would be any better?
Old Jul 28, 2010 | 09:41 AM
  #30
TexasGuy001
Personally I would suggest just going with a Motorcraft, Wix, Purolator OE type filter. The AFE is not an oiled filter.
